I am trying to simulate the effect of a PCB trace on a clock signal with LTSpice, see the following pictures:
In my quick and dirty setup, the clock receiver is the resistor Rin. I the real world, it is a DAC with a CMOS input. Is there an easy way to model such an input in LTSpice? Is the resistor accurate enough?
  • \$\begingroup\$ a sniff of capacitance would be better, 5pF give or take. \$\endgroup\$ – Neil_UK Jan 7 '17 at 21:17
  • \$\begingroup\$ R only? NO Cin depends on family of CMOS and Vdd, of which there are dozens. All CMOS is rated at a fixed load pF which, due to RdsON of output driver limits the slew rate. So which family? More important is to simulate a track w/g dimension ratio to ground with related Zo and length? This gives the 2nd order response to ringing, Not RdsOn*Ciss which is 1st order . ok? \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jan 7 '17 at 22:02
    \$\begingroup\$ (also in real scopes, the length of probe ground and L value. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jan 7 '17 at 22:07
  • \$\begingroup\$ What's wrong with a plain NMOS/PMOS? \$\endgroup\$ – a concerned citizen Jan 8 '17 at 7:09
-3
\$Z_0 = \sqrt{\frac{L}{C}} = \sqrt{\frac{1874,79 \text{nH}}{56,98 \text{pF}}} = 181,3907313029 \Omega\$
add resistor 180Ω (Rin || 180Ω).
| improve this answer | |
  • \$\begingroup\$ Could you please elaborate more on this? \$\endgroup\$ – sergej Jan 9 '17 at 8:55
    \$\begingroup\$ You are calculating the trace impedance, how does it answer the question? \$\endgroup\$ – sergej Jan 9 '17 at 13:12
