If i had a good knowledge in Java programming and know some information about Microcontroller, Can i begin to learn embedded linux? if not, how can i start in this field?
    \$\begingroup\$ Just so you know: In large number of cases, Java and embedded (anything) don't go together. Furthermore since your interest is Linux, you'll need to learn C and C++ in addition to whatever scripting language the shell on the system you'll be working on uses (if you have that in the first place). \$\endgroup\$
    – AndrejaKo
    Mar 13 '12 at 7:35
  • \$\begingroup\$ This could help, also \$\endgroup\$
    – clabacchio
    Mar 13 '12 at 8:44
11
There are some steps before getting on embedded linux. As @KKToronto said, it would be nice if you have a desktop linux experience first. If you don't have any experience I recommend installing Ubuntu in your desktop/notebook in order to get some feeling with the OS.
To go from the desktop to the embedded world, at least on linux way, is relatively easy, if you're planing to develop FOR embedded linux. Almost all drivers interfaces, kernel calls, are the same. One program that runs on a desktop linux, can run on a embedded linux with minor alterations. The beagleboard platform is a good example, as @JobyTaffey noted. Some applications I developed can run on both desktop and the beagleboard without code alterations, just need to use the correct compiler.
Still on the "develop for embedded linux" topic: one of the main alterations is the compiler, mainly because almost all embedded processors that are powerful enough to run linux are ARM ones. From the C/C++/Java programmer it is almost like migrating from x86 to ia64.
If you want to get a deeper "embedded" experience as building device drivers for new hardware, accessing I/O ports on the board, control external equipments using linux, I'd go with Linux Embedded Primer. It is a great book to learn on low level stuff as how the device drivers are made, how to get access to fixed memory locations that represent some peripheral etc. (And it has an amazing lightsaber on the cover =) )
By going on the hardware side a deep microcontroller knowledge is really important, because you're going to be dealing directly with memory for peripheral configuration/access. Some operations may even require assembly knowledge, mainly interruptions or flash writing. It depends a lot on the microcontroller architecture.
If you have no experience on this, I'd recommend to start with arduino, as @stevegt noted, to get a hardware/electronics feeling and then proceed to a baremetal programming over any other processor, to learn some tricks related to hardware/software interface, that are somehow hidden on the arduino firmware or linux kernel.
As you can see that is much knowledge hidden on "embedded linux" expression. Keep in mind that you don't need to have all of it to build an embedded system. You need to focus on what side you want to learn first and get a pre-made system for the other: arduino for hardware first contact, beagleboard to learn programming for embedded linux, a baremetal processor for hardware/software interface.
Specifically for your case I'd recommend the beagle board. As you have some programming and microcontroller background, you can develop some applications in high level to get experience at linux programming and when you fell comfortable enough you could start hardware stuff with the available I/O's on the board.
Get a Linux development board and start hacking!
Choose one with a strong community who can support you. A BeagleBoard would be a good choice. Raspberry Pi may be tempting, but they don't yet have a well established developer community.
You will first need some linux experience. There are many Linux guides online or you can rent books from libraries. Next would be to study these following sites:
http://www.uclinux.org/ http://elinux.org/Main_Page
You may not want to try to run linux on a microcontroller -- it's a tight fit. If you want a microcontroller, I'd say use an Arduino. If you want Linux, you'll need to look for something more expensive, at least something like a gumstix.
The best combination is often an Arduino talking to a Linux host over a USB cable.
You can definitely start learning. Get a BeagleBone, they have a good community and the board has lots of I/O. I've developed a custom design based off the BeagleBone and it works well. TI tech. support it relatively good too.
