6
This question already has an answer here:
I set up TIM3 to fire an interrupt in my project and it just wouldn't work. I tried everything I could and still couldn't find whats the problem. Then I created a clean project and copy/pasted only the code that sets up TIM3 and interrupts and it magically worked. I literally wasted half a day trying to find what causes the problem and it turns out... interrupts don't like C++.
I wrote my code in C++ because I needed classes in my project so naturally I renamed all my prject .c files to .cpp and also compile with the --cpp directive. Everything worked fine, no problems so far until I decided to use interrupts. So I renamed everything to .c and everything worked, renamed everything back to cpp and it stopped working.
I use Keil uVision5 and my projects are generated with STM32CubeMX (only RCC config).
Anyone had this happen to them? Any workarounds?
marked as duplicate by bitsmack, Adam Haun, CL., Voltage Spike, dim Jan 10 '17 at 21:02
This question has been asked before and already has an answer. If those answers do not fully address your question, please ask a new question.
  • 5
    \$\begingroup\$ You may be having issues with C vs C++ linkage - your interrupt handler is probably being subjected to C++ name mangling, so it isn't replacing the default weak interrupt handler that CubeMX provides. \$\endgroup\$ – Devan Jan 10 '17 at 17:51
  • \$\begingroup\$ I just found the solution, and it is exactly what you said. Funny how I wasted half a day looking for a solution only to find it a few minutes after posting the question. \$\endgroup\$ – John Jan 10 '17 at 17:52
  • \$\begingroup\$ This actually is a very well-known problem in embedded. It surprises me somewhat that appropriately chosen search terms didn't immediately give any of the dozens of Keil-Fora, TI-fora, StackOverflow, etc links I seem to get when I try. \$\endgroup\$ – Asmyldof Jan 10 '17 at 18:02
7
I've been searching for a solution for half a day, only to find it a few minutes after I posted this question. The answer is given by this post:
Bug in Keil ARM compiler with interrupt handlers and C++?
The "weak" reference just means that the routine will be replaced by a routine in your code of the same name. When using C this is simple, the names will always be identical but C++ name mangles the functions (for function overloading etc) so the compiled name will probably not match the default ISR name. You need to wrap the function (or at least a forward reference, I'm not sure of specifics I mostly work in C) in an extern "C" wrapper to force the compiler to not mangle the name.
extern "C" { void SysTick_Handler(void) { // do whatever } }
Or you can just declare it as
extern "C" void SysTick_Handler(void);
So you don't have to wrap it.
