I am wondering, if a sychronous generator has a smaller posibility to be burnt (be destroyed permanently) from a short circuit, that has a dc generator with parallel wound or a seperately excited dc generator, and why?
Presuming that both devices had their excitation set to allow them to deliver rated power at rated voltage, a synchronous generator with separately excited field winding and a DC generator with separately excited field winding will both suffer from thermal overload of the armature winding in a sustained fault if the excitation is held constant. The thermal overload may permanently damage the winding depending on the duration of the overload. The DC generator may also suffer damage to the commutator and brushes from the elevated armature current.
| improve this answer | |
The basic difference between the two can be understood from their names, DC generator gives Direct Current(DC) and Synchronous Generator gives Alternating Current(AC).
What is a Generator?
A generator is a electro-mechanical device that converts Mechanical Energy into Electrical Energy.
Working Principle Of DC Generator
What is the principle of generator?
An EMF is induced in a conductor cutting through magnetic flux
  • \$\begingroup\$ Hi Nemish, Welcome to EE.SE. This does not really answer the question. Moreover, your answer contains no information but a link to another website, this link may die in future. Please consider editing the text to a relevant and informative answer. \$\endgroup\$ – Hazem Dec 29 '18 at 8:35
    \$\begingroup\$ Oops, I just found that you are the owner of the website that you've linked. This is considered as a spam on this website. Consider either editing or deleting your answer. \$\endgroup\$ – Hazem Dec 29 '18 at 8:37
  • \$\begingroup\$ @Hazem Now See Answer !! \$\endgroup\$ – Nemish Dec 29 '18 at 8:45
  • \$\begingroup\$ Do you really think that this text (after the edit) answers the main question? \$\endgroup\$ – Hazem Dec 29 '18 at 8:48
