I am trying to make the MFRC522 (https://www.nxp.com/documents/data_sheet/MFRC522.pdf) to work with a taoglas 50-Ohm antenna (http://taoglas.com/images/product_images/original_images/FXR.01.07.0100C.A.pdf)
To start I based my schematic and layout in the arduino RFID board but the problem here is that this board uses a PCB antenna and the circuit is composed with EM filter and impedance matching.
I think that as I am using a 50-Ohm antenna, I don´t need to build the impedance matching part, but the problem is that I can´t find a place I can get a circuit for MFRC522 with a 50-Ohm antenna.
I appreciate all the help!
Thanks!
EDIT:
My question is what is the circuit I need to build between the MFRC522 and the Antenna. And what is the values of the components.
  • \$\begingroup\$ What is your question? \$\endgroup\$
    – Tyler
    Jan 10 '17 at 21:15
  • \$\begingroup\$ What is the circuit I need to build between the mrfc522 and the antenna. And the values of the components Thank! \$\endgroup\$
    – user5343
    Jan 11 '17 at 16:40
    \$\begingroup\$ Please edit your question, to include the question. \$\endgroup\$
    – Tyler
    Jan 11 '17 at 16:44
After a long night I figured out what to do.
This PDF, Design of MF RC500 Matching Circuits and Antennas (alternative source), has a detailed info about how to implement what I wanted.
This is the image of the circuit I implemented, just needed to change some values of caps, but all near to the ones in the image. Worked perfectly.
Values for the EMC- Filter and Receiving Circuit Values for the impedance transformation 50 Ω Short Range solution: 50 Ω impedance transformation using one driver stage
