I have a target board(With Nuc240,Cortex M0) with ADC connected through an OP-Amp(NE5532APSR) as shown in the image.
where AINV1 is the input(0-30 V) and AINVI_ADC is the input to Microcontroller(0-3V) and AINV1_GND - Analog input voltage supply ground
I configured the inputs and I'm getting the Digital values in the range 0 to 4096.
for the 12 bit ADC. The input to Op-Amp(negative feedback) ranges between 0 to 30 volt for which corresponding microcontroller input will be 0 - 3 volt.In the code,should I consider the input resistance R44 and R48 in calculation or just multiply the ADC reading by 7.324*10^-3
ie. -> (3/4096 * 10)
to get the exact input voltage, if not what are the parameters I must consider?
