Question
The above question is that of a past exam paper. I have a few questions regarding some of the theory and calculations behind this. My calculations were as follows: $$ v(t) = 311.13 \angle 0^\circ $$ $$ Z_T = Z_C + Z_L \parallel Z_R $$ If the angular frequency is 314.15 rad/s $$ Z_T = -jX_C + \frac{Z_LZ_R}{Z_L + Z_R} $$ $$ Z_T = -j31.832 + \frac {78.54\angle 90^\circ 100\angle 0^\circ}{100 + j78.54} $$ $$ Z_T = 41.66 \angle 23.7^\circ $$ I do not really understand the intuition behind the Instantaneous versus Average Power calculations. For the instantaneous power in R, my usual calculation is: $$ P_\text{inst} = i(t)v(t) = \frac{v(t)^2}{X_R} \tag 1 $$ Am I allowed to use, say X_c or X_L in place of X_R here if I wanted to find the instantaneous P through the C or L? I have thought that the last part of the above equation was only valid for resistive elements, however I wouldn't know how to find instantaneous \$P\$ through \$C\$ or \$L\$ otherwise.
For the average power, there has been some debate amongst my classmates as to whether the average power is defined by: $$ P_\text{avg} = \frac{1}{2} IV \cos\varphi \tag 2 $$ or $$ P_\text{avg} = \frac 1 T \int_0 ^T P_\text{inst} \tag 3 $$ I know that equation (2) is the real power dissipated by the system, but am confused between that and the average power dissipated by the system. In addition I am aware equation (2) is a derivation of (3), however I am not sure if one can apply (2) for any instantaneous P, or if there are cases where one must use (3).
I appreciate that this is a lengthy question so in summary:
Can one use the reactance of C or L in equation (1)?
What are the essential differences between real power and average power? Can one use equation (2) instead of (3)?
  • \$\begingroup\$ \$X_L\$ is only j0.0785 ohms and not what you got. \$\endgroup\$
    Jan 11, 2017 at 18:21
  • \$\begingroup\$ You need to rework XC too (31.83 ohms) \$\endgroup\$
    Jan 11, 2017 at 18:22
  • \$\begingroup\$ Apologies, L should be 250 mH, will edit \$\endgroup\$
    – user120568
    Jan 11, 2017 at 18:24
  • \$\begingroup\$ If you have a phase angle >90* or <-90* it means either you have a negative resistance (a.k.a. something supplying power, not dissipating it), or you have calculated something wrong. \$\endgroup\$ Jan 11, 2017 at 18:36
  • \$\begingroup\$ Why do you feel that a phase angle needs to be 'adjusted'? Either you've calculated it correctly or you haven't. It also makes sense to stick to either complex or polar notation; mixing the two is asking for trouble. \$\endgroup\$
    – Chu
    Jan 11, 2017 at 19:42
In your equation (1), the inst. power in the resistor \$ P = v_r(t) i_r(t) \$, so it is the voltage over the resistor, not the sources' voltage.
If you are considering the Instantaneous Power, then you should be dealing with the instantaneous current and voltage, which are sinusoidals. For resistors, this should be
$$ P = v_r(t) i_r(t) $$
but with ohms law
$$ v_r(t) = R i_r(t) $$
then we get
$$ P = \frac{v_r(t)^2}{R} = \frac{|V_r|^2 \cos(\omega t+\angle V_r)^2}{R} $$
\$|V_r|\angle V_r\$ is the phasor magnitude and angle that you obtain with your phasor calculations.
enter image description here Note that this is a signal where the mean is equal to the amplitude. This is always true when we consider active power. So the average power = mean of the instantaneous power = amplitude of the sine wave = \$\frac{V_r^2}{R}\$.
If you do the same with something pure reactive, lets say a capacitor, you get
$$ P = v_c(t) i_c(t) $$
then we know that, for a capacitor (or inductor), the current will be 90 out of phase with the voltage. If we consider the voltage as a sine, than the current would be a cosine in the instantaneous power:
$$ P = v_c(t) i_c(t) = V \sin(\omega t) \cos(\omega t) $$
The result is a power that has average equal to zero:
And what we call reactive power is the amplitude of this zero-mean sinusoidal wave. It's just some instantaneous power coming back and forth, so it doesn't do, in a cycle, any net work.
So the real power will always be the average of the instantaneous power.
When you have a little bit of active and reactive (dashed line in the figure below), you can always decompose the instantaneous power waveform two sinusoidal signals: one which is always positive (like the resistor), where the mean and amplitude is equal to the active power and other with zero mean, with amplitude equal to the reactive power. You can see them in the picture.
Note that the average of the overall inst. power is equal to the average of the "resistor like" part (always positive signal).
To your questions:
1- To find instantaneous power you always have to go from the instantaneous voltage and current as I've done. This formula in (1) you presented is only valid for resistors. And note again that it should be the voltage over the resistor.
2- (2) and (3) are equivalent for pure sinusoidal systems (with no harmonic distortion)
Multiplying the rms values of the source voltage and current gives apparent power. Apparent power is made up of the real power which is being dissipated in the resistor and the reactive power which is flowing backwards and forwards between the reactive elements (C & L) and the source. There isn't any power actually being dissipated in either C or L (assuming they are ideal).
Equation 1 can be used with XL or XC and gives the instantaneous power flowing in the component, this power flowing in will later flow out and is not dissipated in the component. The power is used to charge the electric field in the capacitor and the magnetic field in the inductor and will be returned to the source when the fields collapse. The average of the instantaneous power in each reactive component is zero. That is to say that the average of the reactive power is zero, all reactive power that is supplied from the source is returned to it.
Equation 2 can only be used with sinusoids.
Equation 3 can be used with any shaped waveform.
