I was wondering if it would be possible to connect an IO extender (MCP23017-E/SP) to an ATMega32u4-AU via an USB cable.
I figured that if you connect up the SCL pin to the Data+ of the USB and the SCA pin to the Data- of USB, ground the 4th pin and power the 1st it should work.
Am I correct with this?
Image example in Kicad schematic:
    \$\begingroup\$ It should work for short distance cable. Bus capacitance may be addressed by reducing the I2C speed to minimal if possible. \$\endgroup\$
    – User323693
    Jan 12, 2017 at 1:36
  • \$\begingroup\$ @Umar how short of a distance are we talking about here? Haha. I was planning on having it run through about a 6inch to 1 foot cable. \$\endgroup\$
    – Meowlfhelm
    Jan 12, 2017 at 1:49
  • \$\begingroup\$ That should do. \$\endgroup\$
    – User323693
    Jan 12, 2017 at 1:52
There should be no problem. The original Nunchuk for the Nintendo Wii game system connected to the Wii Remote via a 1 to 1.2m (3.5 to 4 feet) long cable, very similar to a USB cable (six pin connector, but only four were used). The Nunchuk contained a a 2-axis joystick, two buttons and a 3 axis ±2g accelerometer and used a I2C interface to communicate with the remote, running at 100 kHz as documented here and here. Sparkfun even sells a little breakout board for hobbyists building their own interfaces.
  • \$\begingroup\$ Perfect! Thank you so much! Ill be using it to run a 5x7 matrix for a keyboard :) should be easy. Might get more complicated if I do LED's in a future batch. But thank you so much! :) \$\endgroup\$
    – Meowlfhelm
    Jan 12, 2017 at 6:09
Where are the pullup resistors for SDA and SCL ?
The problem with I2C is cable capacitance (already mentioned), crosstalk between SDA and SCL, pullup resistors and voltage differences.
Are both running at 5V ? Then that is okay. You can use pullup resistors at the Master of 2k2 for SDA and SCL.
It is only a short cable, so it should be possible. You could try the MultiSpeed I2C Scanner. It it runs at 400kHz, then 100kHz or is very safe to use.
  • \$\begingroup\$ I have updated it. Added pullups resistors just to be safe. It will already be running at 5v. So there shouldn't be any problems at all. \$\endgroup\$
    – Meowlfhelm
    Jan 23, 2017 at 8:44
  • \$\begingroup\$ No guarantees, but it should work. Run that test with 400kHz. As a backup plan, the Wire.setClock can be used to lower the speed to 50kHz. \$\endgroup\$
    – Jot
    Jan 24, 2017 at 20:10
