My problem is that my bootloader is not jumping to the application, or maybe it is but then jumps back to the bootloader because of an interrupt. To give you something to work with here are some info:
The code that jumps to the application
typedef void (*pFunction)(void);
pFunction Jump_To_Firmware;
void JumpToInternalFlashImage()
Jump_To_Firmware = (pFunction) (*(uint32_t *)(0x08008000 + 4));
__set_MSP(*(uint32_t*) 0x08008000);
Jump_To_Firmware();
How main looks in the application
int main(void)
// Copy ISRs to RAM
memcpy((uint8_t *)&_isr_vector_ram_start, (uint8_t *)&_isr_vector_flash_start, &_isr_vector_flash_end - &_isr_vector_flash_start);
// Relocate the vector table
SCB->VTOR = (uint32_t) &_isr_vector_ram_start;
HAL_Init();
SystemClock_Config();
MX_GPIO_Init();
MX_DMA_Init();
MX_USART2_UART_Init();
while (1)
HAL_UART_Transmit_DMA(&huart2, "hello", 5);
uint32_t i =0;
for(;i<1000000;i++);
It should perhaps be pointed out that this program works fine if I program it through ST link without any bootloader code. Also the important parts of this code should be the first lines where I copy the ISRs to RAM and then relocate the vector
The linkerscript looks like the following to give you an idea of where the addresses come from ( it looks the same in both bootloader and application )
/* Entry Point */
ENTRY(Reset_Handler)
/* Highest address of the user mode stack */
_estack = 0x20050000; /* end of SRAM2 */
/* Generate a link error if heap and stack don't fit into RAM */
_Min_Heap_Size = 0; /* required amount of heap */
_Min_Stack_Size = 0x400; /* required amount of stack */
// There are more areas but these should be the only relevant ones
MEMORY
FLASH (rx) : ORIGIN = 0x08000000, LENGTH = 1024K
RAM_ISR (xrw) : ORIGIN = 0x20000000, LENGTH = 512
RAM (xrw) : ORIGIN = 0x20000200, LENGTH = 64K - 512
SECTIONS
/* The startup code goes first into FLASH */
.isr_vector :
. = ALIGN(4);
_isr_vector_flash_start = .;
KEEP(*(.isr_vector)) /* Startup code */
_isr_vector_flash_end = .;
. = ALIGN(4);
} >FLASH
._isr_vector_ram (NOLOAD) :
. = ALIGN(4);
_isr_vector_ram_start = .;
KEEP(*(._isr_vector_ram)) /* Startup code */
. = ALIGN(4);
}>RAM_ISR
So my problem is that when I try to jump to the application it doesn't work
The first addresses from 0x8008000 ( application start address ) looks like
And at the address 0x08004DD1 it looks like
What happens is that I always end up stuck when the program counter points at(it does not move from this address when trying to step further )
0x8007770
and MSP
0x2004ffe0
in the output.map for the bootloader I can see that 0x08007770 is
.text.Default_Handler
0x08007770 0x2 startup/startup_stm32f746xx.o
0x08007770 RTC_Alarm_IRQHandler
0x08007770 EXTI2_IRQHandler
0x08007770 TIM8_CC_IRQHandler
0x08007770 DebugMon_Handler
0x08007770 UART8_IRQHandler
0x08007770 SPI4_IRQHandler
0x08007770 TIM1_CC_IRQHandler
0x08007770 DMA2_Stream5_IRQHandler
0x08007770 HardFault_Handler
and so on (the rest of the handlers )
Does anyone know what my problem is and how to solve it ? Please feel free to ask questions if you feel like I've missed to tell you something
i
be declaredvolatile
to avoid the loop being removed by the compiler's optimiser? \$\endgroup\$
