I've written this code for a counter, but I don't know why it doesn't work. The output remains at zero, and when I change load to 0, output changes to unknown.
Would you please help me to find the error?
module behav_counter( d, clk, clear, load, up_down, qd);
 input   [7:0] d;
 input   clk;
 input   clear;
 input   load;
 input   up_down;
 output  [7:0] qd;
 reg     [7:0] cnt;
always @ (posedge clk or negedge clear)
if (!clear)
    cnt = 8'h00;
else if (load)
    cnt = d;
else if (up_down)
    cnt = cnt + 1;
else
    cnt = cnt - 1;
assign qd = cnt;
endmodule
module test_b;
  reg d,clk,clear,load,up_down;
  wire qd;
  behav_counter bc( d, clk, clear, load, up_down, qd);
  initial
  begin
       clear = 0;
       clk = 0;
       #15 clear = 1;
       repeat (400)
         #5 clk = ~clk;
  end
  initial
  begin
     up_down=1;
     load=1;
     d=8'h00;
     #23
     load=0;
     #100
     load=1;
   end
endmodule
When I run your code on 2 different simulators, I get compile warnings about port size differences for d and qd. Your counter declares them as 8-bit wide, but you connect 1-bit signals to them. If you don't get warnings, try it on edaplayground.
In test_b, declare them as 8-bit:
module test_b;
 reg clk,clear,load,up_down;
 reg  [7:0] d;
 wire [7:0] qd;
Now I see qd[7:0] count up from 0 to 0xa when load=0.
