I need to step up a 9V power supply (from a battery) to (at least) 45V, very small output current (less than 1mA, but it may be much less). My purpose is to drive a Russian rod vacuum tube, which needs 45V on its screen grid, and works best with about 60V on its anode (but the latter request may be reduced a lot). The current drawn by the screen grid is negligible, and the anodic current won't be more than 1mA.
I am thinking about a charge pump voltage multiplier; Maxim has many of them, but I have not been able to locate an IC suitable to multiply the input voltage by a factor greater than 2. I do not want to use boost converters, since I do not want to introduce an inductor in my circuit.
A possible solution would be that of connecting two charge pumps in cascade, but I wonder whether someone has a better and simpler idea.
  • \$\begingroup\$ Why not an inductor? A boost converter is the ideal choice. \$\endgroup\$
    – winny
    Commented Jan 14, 2017 at 22:49
    \$\begingroup\$ Charge pumps are lossy due to ESR and 45mW out may need at least 200mW input with many stages whereas a boost regulator can be easily>90% efficient and better regulated with load current. \$\endgroup\$ Commented Jan 14, 2017 at 23:25
  • \$\begingroup\$ Your requirements are conflicting. Hidden in a comment (new information should really be added to the question) you say the reason for avoiding inductors is cost. That might matter in a high volume design. But then you say you want thru hole, which clearly says this is not a serious high volume design. This very much smells like a hobbyist fixating on one or two parameters and ignoring the bigger picture. If you're building one of these, then how is $2 in parts cost relevant? Also by insisting on archaic thru hole, you severely limit the choices and make everything harder to solder. \$\endgroup\$ Commented Jan 15, 2017 at 14:05
  • \$\begingroup\$ @OlinLathrop Yes, it is a semi-hobbyist design. Not intended for mass production. I understand I limit the choices, but I do not understand how everything be harder to solder---how could I solder SMD devices without the proper equipment (which I do not own)? \$\endgroup\$
    – Enrico
    Commented Jan 15, 2017 at 15:17
    \$\begingroup\$ If you only have a soldering iron, you should avoid leadless packages like QFN or BGA. However, that still leaves many many parts available to you. Being able to use transistors in SOT-23 packages, microcontrollers in SOIC-28, TQFP-44, etc, is very useful. Many modern parts simply aren't available in thru hole because there is no market for such packages. \$\endgroup\$ Commented Jan 15, 2017 at 17:16
A basic capacitive charge pump can only double the voltage, minus voltage drops in diodes. You would need at least 3 stages of doubling. Other types of charge pumps add the input voltage (again, minus a bit) to the output each stagle. For such a charge pump you need at least 6 stages, since 45 is exactly 9 x 5, so 5 stages can't get there due to some inevitable loss.
So what's the solution? A boost converter. That uses a inductor to boost the voltage. You say you don't want to use a inductor. However, you provide no justification for that, so this is still a valid answer. We are not here to indulge your religious hangups.
A flyback converter uses a transformer. I don't know if such a beast falls into the catagory of evil inductors in your belief system. The sacred scrolls can be interpreted either way. In any case, a transformer-based power supply, whether in flyback or forward mode, can do this in a single stage, just like a inductor-based boost converter.
  • \$\begingroup\$ No religion here. I'd just like to save room and money, that's the reason for leaving out an inductor. But anyway, you convinced me that a boost converter is better, so I will convert my religious belief to inductors. Now the question turns to: are there around IC's suitable to my needs, I mean, suitable to very low output current, maybe without an external MOSFET? (I would add the request that the package be a through-hole device, not a SMD one.) But maybe now I am moving a bit off-topic and requesting info about specific products, I don't know. \$\endgroup\$
    – Enrico
    Commented Jan 14, 2017 at 23:46
  • \$\begingroup\$ @Enrico check out Linear Technology ICs \$\endgroup\$
    – crowie
    Commented Jan 15, 2017 at 2:53
  • \$\begingroup\$ @crowie The LT1172 seems to me a good choice. It is available in 8-pin PDIP. But the available application notes list quite complicated circuits. I'd need some help to simplify them and focus on my needs. \$\endgroup\$
    – Enrico
    Commented Jan 15, 2017 at 10:52
  • \$\begingroup\$ Since the output voltage of charge pump circuit using SMPS drops when current is drawn, what will happen when we have multiple stages of them in series? \$\endgroup\$
    – quantum231
    Commented Apr 15, 2023 at 3:37
Voltage multipliers will work out to 10* and 12* without any problem. But you need a reasonable high frequency (several kHz) and as noted you will end up using significantly more power to create your 45 V supply than you would using an inductor. If you need regulated 45 V then you may need to go to 6* or 7* because of the voltage drops over the diodes.
You could start here or here for some design guidelines and information. I've seen simple NE555 designs used out to 4*, I'm sure you could make one work at 5*.
If you want to design a boost regulated supply you can do no better than TI's Webench. This application can lead you through a design almost step by step or provide you with a starting point to further develop a solution. I put 9 V --> 45 V @ 100mA and it pointed out the LM2588 which is very much overkill, but it may give you some pointers.
  • \$\begingroup\$ Thanks for the useful references---anyway, you all have convinced me that a boost converter, with an inductor, would be better. But I see there are many around: could you please provide me with a good starting point for such a design? \$\endgroup\$
    – Enrico
    Commented Jan 14, 2017 at 23:55
