As a learning exercise, I am attempting to make a step-up DC converter (5V to 12V). The basic design I'm following is this:
Source: http://www.daycounter.com/LabBook/BoostConverter/Boost-Converter-Equations.phtml
From the source above, I've derived an equation for a value of L1 which will avoid an unstable output voltage (I'm ignoring Vtransistor since it seems to be negligible for my components):
$$ L \ge {V_{in} (V_{out} + V_{diode} - V_{in}) \over {f (V_{out} + V_{diode}) \min(I_{load})}} $$
I'm using an IRF520 MOSFET and an IN4007 diode, with an Arduino providing the PWM source (running at 62.5kHz), so I believe this fills in as:
$$ L \ge {5\text{V} \times (12\text{V} + 1.1\text{V} - 5\text{V}) \over {62500\text{Hz} \times (12\text{V} + 1.1\text{V}) \times 0.0001\text{A}}} = {40.5\text{V}^2 \over {81.875 \text{V} \text{A} / \text{s}}} = 0.495\text{H} $$
(to guarantee the 100µA minimum load, I'm putting a 100kΩ resistor in series with the diode, although I'm not sure this is the right thing to do since it will be dividing the output voltage. I guess that once I have something for this to drive I'll have to recalculate the value for the specific circuit)
So that gives me a number, but 0.495H seems like a huge value, and I'd rather not accidentally produce 100V if I mess up the PWM duty cycle.
I have two questions: does this look at all reasonable? and is there some way I can calculate the maximum obtainable voltage from a given inductor in this setup?
