I don't recognize this component, maybe some of you will. I measure 10.6 ohms across it. I believe it might be an inductor or filter bead, but i need to be sure. As you can see in the picture, it says 105K , 4083, and that is it.
I'll point out that this board is no longer working, and i'm looking for a faulty component, so the measurment i took (10.6 ohms) could be the result of measuring a component that no longer works as it should.
Note: in the circuit, there are no parallel components with this item, so i believe the measurement to be accurate
    \$\begingroup\$ It's a power inductor made by EPCOS. It's similar to this, but probably not identical. I cannot tell the size from your photo. \$\endgroup\$
    – Steve G
    Jan 16, 2017 at 16:24
  • \$\begingroup\$ That appears to be a 1 micro (something) 10% device but I don't have time to search for the manufacturer. \$\endgroup\$ Jan 16, 2017 at 16:27
    \$\begingroup\$ Probably not the source of your problem, since it does not look burned and measures a reasonable resistance. Look for a fuse and/or semiconductor, most likely. \$\endgroup\$ Jan 16, 2017 at 18:01
It appears to me that it might be something similar to the following: SMT Inductors
I do not know exactly what the parameters are for this device, but I would guess it is a 1mH, 10% tolerance device with a 12 Ohms DC resistance.
To make sure it is the correct device, look on TDK website for Fixed Inductors. Here is the package that I found online for it:
Any inductor will have some series resistance associate with it. This is the reason why you would read 10.6ohms across the inductor.
