In as few words as possible, here is my question:
Why can we get the output phasor by multiplying the input phasor by the s-domain transfer function evaluated at the (complex?) frequency we're dealing with?
An example will serve to better explain:
(Note: I am tacitly ignoring the initial conditions; for now I want to simplify the problem and only consider the steady-state response)
$$H(s)=\frac{V_C}{V_{in}}=\frac{1/(sC)}{sL+R+1/(sC)}=\frac{\frac 1{LC}}{s^2+s\frac R L +\frac 1{LC}}$$
If we wanted \$V_C\$­ as a phasor, we would simply perform
$$V_C = V_{in}\cdot H(j2\pi \cdot1000)=3\angle45˚\cdot \frac{\frac 1{LC}}{-4\pi^2 \cdot 1000^2+j2\pi \cdot 1000\frac R L +\frac 1{LC}}$$
This would result in some complex number, which we would interpret as representing a sinusoid in the time domain. (Note: Already I'm confused... the input voltage waveform is not a complex number in the s-domain; it's actually some function of s).
I can understand how phasors arise naturally when solving DEs in the time domain; you assume your output is of the form \$Ae^{j2\pi ft + \phi}\$ and the time-dependence cancels out in the equation. I can also understand that multiplying by the transfer function in the s-domain produces the correct output in the time domain (provided the system is LTI). I can even understand why Ohm's Law, KVL, and KCL work in the s-domain.
However, after all that I can't get my head around this "abuse of notation". Phasors and s-domain expressions shouldn't have any business hanging around each other! So what am I missing here?
4 Answers 4
Actually, phasors and s-domain expression do have some relationship. Recall that the 's' variable in the laplace transform is defined as:
$$ s = \sigma + \text{j}\omega$$
So, when you substitute \$s\$ by \$\text{j}\omega\$ in a transfer function, you are taking your function to the phasor domain (which will produce the steady-state solution only, not the transient response).
Now, remember that when using phasors, you're taking advantage of Euler's identity, that is, \$e^{\text{j}\omega t}=\cos(\omega t)+\text{j}\sin(\omega t)\$. Even though you have a real source, say it is \$v(t)=\text{V}_o\cos(\omega t)\$, you can use Euler's identity to express it as
$$ v(t)=\text{V}_oe^{\text{j}\omega t}$$
or more rigorously defined as
$$ v(t)=\Re{[\text{V}_oe^{\text{j}\omega t}]}$$
where \$\Re\$ means that you want the real part of the expression. That's the case since your source is a cosine, or the real part of Euler's identity.
Alternatively, if you source were a sine, then
$$ v(t)=\Im{[\text{V}_oe^{\text{j}\omega t}]}$$
where \$\Im\$ means that you want the imaginary part of Euler's identity.
That means, that once you solve your circuit, you need to take either the real (if your source was a cosine) or the imaginary (if your source was a sine) part of the complex valued solution.
Hope it helps!
  • \$\begingroup\$ I do understand that evaluating a Laplace transform at \$j\omega \$ gives us the frequency domain, however, I still don't understand how phasors apply. In the frequency domain, a cosine is represented as two delta functions, not a complex number. Why should multiplying the input phasor by the frequency-domain transfer function evaluated at the frequency we're dealing with give us the output phasor? \$\endgroup\$
    – Mahkoe
    Jan 17, 2017 at 12:27
  • \$\begingroup\$ @Mahkoe a phasor represents a complex number, so does the frequency domain transfer function (it has the imaginary unit j in it). That is, the frequency domain tf is complex. You can further take the frequency domain transfer function and express it in polar form since it is complex. Now all you have is two quantities, in polar form (the input phasor and the phasor representation of the tf), once you multiply them together, you obtain another quantity in polar form, which is a phasor. \$\endgroup\$
    – Big6
    Jan 17, 2017 at 17:27
The Laplace transform of \$f(t)\$ is defined as: $$F(s)=\int_{-\infty}^{\infty}e^{-st}f(t)dt$$ and the Fourier transform of \$f(t)\$ is defined as: $$F(j\omega)=\int_{-\infty}^{\infty}e^{-j\omega t}f(t)dt$$ Clearly, the substitution \$s\large\leftrightarrow\small j\omega \$ performs the transformation between the two domains.
For TF analysis we assume zero initial conditions, so, for example, \$cos(\omega t)\$ should be replaced with \$u(t)cos(\omega t)\$, and the corresponding Fourier transform is \$\large \frac{j\omega}{{\omega _0}^2-\omega ^2}\$, which is obtained from \$s\rightarrow j\omega\$ in the LT for \$cos(\omega t)\$; viz \$\large \frac{s}{s^2+{\omega _0}^2}\$
  • \$\begingroup\$ Okay, but I don't see how phasors and frequency-domain expressions belong together. In the frequency-domain a cosine is two delta functions, not a complex number. Why should multiplying the input phasor by the frequency-domain transfer function still produce the correct output phasor? \$\endgroup\$
    – Mahkoe
    Jan 17, 2017 at 12:29
  • \$\begingroup\$ For TF analysis we assume zero initial conditions, so, for example \$cos(\omega t)\$ should be replaced with \$u(t)cos(\omega t)\$, and the corresponding Fourier transform is \$\large \frac{j\omega}{{\omega _0}^2-\omega ^2}\$, which is obtained from \$s\rightarrow j\omega\$ in the LT for \$cos(\omega t)\$; viz \$\large \frac{s}{s^2+{\omega _0}^2}\$ \$\endgroup\$
    – Chu
    Jan 17, 2017 at 14:35
  • \$\begingroup\$ But this isn't a phasor at all. Not only is it not equal to the phasor representation of the cosine, but phasors represent steady state (that is, to recover the original time-domain signal from a phasor, you simply multiply by \$e^{st}\$, where \$s\$ is your complex frequency \$\sigma + j\omega \$. There are no unit step functions involved) \$\endgroup\$
    – Mahkoe
    Jan 17, 2017 at 16:45
  • \$\begingroup\$ u(t) in this context forces the cosine to zero for negative time. \$\endgroup\$
    – Chu
    Jan 17, 2017 at 17:10
You can manually derive the general sinusoidal steady-state response for LTI systems and this relationship becomes clear. Let \$H(s)\$ be the system's transfer function, \$h(t)\$ be the impulse response (the inverse Laplace transform of the transfer function), and \$V_C(t)\$ be the steady-state response. With a generalized sinusoidal input \$g(t)=V_{in}\sin(\omega t+\theta)\$, the overall response, by the convolution theorem, is as follows: $$\int_0^t{h(\tau)g(t-\tau)d\tau}$$ $$=\int_0^\infty{h(\tau)g(t-\tau)d\tau}-\int_t^\infty{h(\tau)g(t-\tau)d\tau}$$ Since systems made purely of RLC components are stable in nature, it's intuitive that the second term decays as \$t\$ approaches \$\infty\$ and the first term doesn't, so you can tell the first term is the steady-state response \$V_C(t)\$. $$V_C(t)=\int_0^\infty{h(\tau)g(t-\tau)d\tau}=V_{in}\int_0^\infty{h(\tau)\sin(\omega (t-\tau)+\theta)d\tau}$$ Euler's formula: \$\sin(z)=\frac{e^{jz}-e^{-jz}}{2j}\$ $$=\frac{V_{in}}{2j}\int_0^\infty{h(\tau)\left(e^{j(\omega(t-\tau)+\theta)}-e^{-j(\omega(t-\tau)+\theta)}\right)d\tau}$$ $$=\frac{V_{in}}{2j}\left(e^{j(\omega t+\theta)}\int_0^\infty{h(\tau)e^{-j\omega\tau}d\tau}-e^{-j(\omega t+\theta)}\int_0^\infty{h(\tau)e^{j\omega\tau}d\tau}\right)$$ The transfer function evaluated at \$j\omega\$: \$\int_0^\infty{h(\tau)e^{-j\omega \tau}d\tau}=H(j\omega)\$ $$=\frac{V_{in}}{2j}\left(e^{j(\omega t+\theta)}H(j\omega)-e^{-j(\omega t+\theta)}H(-j\omega)\right)$$ $$\small{=\frac{V_{in}}{2j}((\cos(\omega t+\theta)+j\sin(\omega t+\theta))H(j\omega)-(\cos(\omega t+\theta)-j\sin(\omega t+\theta))H(-j\omega))}$$ $$=V_{in}\left(\frac{H(j\omega)-H(-j\omega)}{2j}\cos(\omega t+\theta)+\frac{H(j\omega)+H(-j\omega)}{2}\sin(\omega t+\theta)\right)$$ Since \$H(-j\omega)=\overline{H(j\omega)}\$, $$=V_{in}(\mathfrak{I}(H(j\omega))\cos(\omega t+\theta)+\mathfrak{R}(H(j\omega))\sin(\omega t+\theta))$$ $$V_C(t)=V_{in}|H(j\omega)|\sin(\omega t+\theta+\angle H(j\omega))$$ This implies that the output is simply the same sinusoid as the input, scaled by a factor and shifted by a phase angle completely determined by \$H(j\omega)\$. Specifically, if you were to transform this to a phasor, you get exactly the product \$(V_{in}\angle\theta)(H(j\omega))\$.
For the Laplace transform of a system with its input and output represented by phasors, you can refer to pages 44 to 47 of my paper "Timing, Synchronization and LLRF, The 6th OCPA Accelerator Topical School and Workshop, Beijing, China, October 14-18, 2019" available here
Research gate link here
    \$\begingroup\$ Could you please put the relavent information into the post, if the link changes the answer not help anyone \$\endgroup\$
    – Voltage Spike
    Mar 8, 2021 at 22:05
