I am working on PCIe 3.0 compliance testing from signal integrity and power integrity point of view. I would like to understand the difference between IBIS and IBIS-AMI model and which model is good for my simulation? These models are used in transient and channel simulation of PCIe 3.0.
  • \$\begingroup\$ After some search, I found below answer. The IBIS (Input/output Buffer Information Specification) models are a behavioral model using I-V and V-t look-up tables that make simulations extremely fast. At high speed with the decision-feedback equalizer and feed-forward equalizer (FFE), the IBIS specification is no longer sufficient to represent the TX and RX circuits and to overcome this problem an extension to IBIS has been developed known as IBIS-AMI (Algorithmic Modeling Interface). The IBIS-AMI model enables fast, accurate, statistically significant simulation of multi-gigabit serial links. \$\endgroup\$ Jan 24 '17 at 8:40
The IBIS file is the representation of the analog section of the chip which generally include I-V & V-T look-up tables. IBIS files are behavioral models of individual analog buffers. As the chip designs became more and more complex, more DSP techniques were needed to maintain an open eye at the receiver data slicer. While the IBIS Open Forum worked with the industry to amend the IBIS standard to incorporate changes, analog IBIS buffer models could no longer keep up with the DSP design. Vendors were again providing their own encrypted models which were platform specific. Thus the IBIS community worked to extend the IBIS models and IBIS-AMI models were born. AMI stands for Algorithmic Modeling Interface and as the name indicates, it is designed to handle modeling of the algorithmic functions of an I/O, namely the DSP. IBIS-AMI models provide the end user with the model portability that they need while ensuring the vendors that their IP is protected. The user settable parameters for equalization are generally included in the AMI file.
