I'm having some hickups with an providing supply voltage to UCC28C44 PWM controller. I have noticed that when I remove resistor RS7, VDD voltage rises to 18V as I expect. If RS7 is there the voltage is zero so I'm guessing that IC is broken somehow and that it has turned into a short circuit. Does it sound reasonable?
brokenIC
  • \$\begingroup\$ You can always replace by a known good and check... \$\endgroup\$ – PlasmaHH Jan 18 '17 at 13:11
  • \$\begingroup\$ Replaced it. It was broken. For future reference, a broken IC can turn into a short. \$\endgroup\$ – MarkoP Jan 18 '17 at 15:05
