How would I go about adding 3g wireless capability to an embedded project? Initially I thought about just using a USB host controller and purchasing a USB 3G card. This idea however seems "hackish" and not permanent. What would be the best way to do this?
  • \$\begingroup\$ Is this a one-off project or something that will go into production? \$\endgroup\$ – tcrosley Mar 15 '12 at 17:27
  • \$\begingroup\$ ideally something that will go into production. It is going to be a small embedded windows machine \$\endgroup\$ – sirpkt Mar 15 '12 at 18:03
    \$\begingroup\$ If it's running any significant version of Windows don't you essentially get USB for 'free'? I'd think the USB dongle would be best. \$\endgroup\$ – AngryEE Mar 16 '12 at 15:40
You can use a solderable 3G module with serial interface.
I recently completed a design using the AirPrime SL series from Sierra Wireless. They provide 3GPP HSPA+/GSM and EV-DO/CDMA in various modules that are pin-compatible. They can be interfaced using AT-type commands via a UART.
| improve this answer | |
I would have to agree with tcrosley. I've used a few different 3G modules (from different manufacturers) and Sierra Wireless has really great documentation for both integration and interfacing. Additionally, they don't seem to require a lot of additional components to get it running properly. I've run them from both the USB interface and a UART interface with success.
You just have to be prepared to add some space to your PCB for the module, antenna, and appropriate spacings to reduce the risk of interface. The SL8080T is their new low-cost module with embedded GPS if you're into that sorta thing.
