I'm a photonics student trying to develop a Transimpedance amplifier for use as a drop in replacement in a photo-detection circuit. I've run in to a wall while designing the circuit. I want a Bandwidth from around 5kHz to 2GHz, a 26dB+ gain and a noise figure around 3-4dB, but no matter what I try I can't get my noise figure below 20 when modelling in Multisim. Circuit I've made so far
Noise In/Noise Out Figure from multisim
An help in figuring out what I can do would be greatly appreciated. I'd also like to know how I could get rid of the 10 Mohm resistors, but the circuit doesn't seem to work right without them.
THANKS!
  • \$\begingroup\$ Are you open to a solution using an IC instead of designing it yourself using discrete transistors? I believe you will find it challenging to implement a TIA with your desired specifications using discrete transistors. \$\endgroup\$
    – user57037
    Jan 22, 2017 at 19:50
  • \$\begingroup\$ Not sure you can do this even using nice TIA op-amps. It is a LOT of bandwidth you are looking for. \$\endgroup\$
    – user57037
    Jan 22, 2017 at 19:57
  • 4
    \$\begingroup\$ Where do you expect the gain is going to come from? 2N2222 transistors run out of steam at a few hundred MHz. \$\endgroup\$ Jan 22, 2017 at 20:24
  • \$\begingroup\$ Go to NXP's website and choose transistors that have an fT of several GHz. \$\endgroup\$
    Jan 22, 2017 at 21:11
  • 4
    \$\begingroup\$ You also need desperately to talk to somebody who is familiar with GHz circuit design. For instance, using a 20 uF blocking capacitor for GHz signals is guaranteed to fail. Not to mention your 10 milli-ohm emitter resistors. And your 30 Mohm resistance with no consideration for parasitic capacitances. Plus the fact that you don't have a transimpedance amplifier at all - you have a 50-ohm sense resistor followed by a completely inadequate voltage amplifier. \$\endgroup\$ Jan 22, 2017 at 21:37
First, lets not worry about the gain, but lets get the delta-charge from the photodiode converted into a healthy, buffered delta-voltage on output of a first stage. Assume the 20pF of PhotoDiode sets the total (sqrt(kt/c) noise floor, which is 7microvolts RMS. Your signal is 50uVpeak, or 25uV above or below some detection threshold. What can we do with that?
Let's bias a CE NPN bipolar at 26mA, providing GM of 1amp/volt or 50uA/50uV. Assuming the collector resistor is 100 ohms (low in value, so we have some legit hope in reaching 2GHz BW), our output delta-voltage is 50uA * 100 ohms, or 5 milliVolts. [by the way, 1pF and 100 ohms is 100pS, or 1.6GHz F3dB]
Put an emitter follower on that, running at 10mA so Rout is 2.6 ohms, and AC couple THAT into a copy of the first stage, producing 500 millivolt output.
With nary a TIA in sight. The 2SC5646A has 12.5GHz Ftau at 3 volts and 15mA, with Cob of 0.5pF typical.
Caveats: (1) the photodiode capacitance may cause oscillation of the CommonBase Q1. If so, solder SurfaceMount 10Ohms directly under the transistor base. Literally lift up the SOT-23 base lead and slip a 10 Ohm under that lead. (2) for more speed, boost VDD; or reduce R1 to 50 Ohms; R1 has 0.5 + 0.5pF in parallel (COb Q1, Cob Q2), or 100picoSec tau, only 1.6GHz. (3) reduce the transconductance_setting resistor [we want gm of 1/1_ohm] to 33 or 24 ohms, and reduce the pot base voltage; this provides more Vce on Q1 for higher bandwidth. (4) circuit has little headroom on Q2, so may saturate; consider reducing the lower collector resistor for more headroom.
What do we (think we) have here? Collector tau of 100 ohm * 0.5pF (only 1 of the Cob loads) or 50 picosecond Tau, supporting 15GB/sec datarates. With 20uA input, we get 100 ohm * 20uA = 2 milliVolts output (from Q1 collector, Q2 emitter) at 2.6 ohms Rout, or ~~ 50x the current as the PD provided.
We can trade off gain for bandwidth, increasing R1 to 200 ohms with 100pS tau. That requires using 6 volts VDD and reducing Remitter of Q1.
