Can AT90USBKEY be used as dev. board for USB host device?
What I would like to try is to use this board to check if I can send SCPI commands to some third party device via USB.
And can this usb miniAB from this dev. board be used to connect to usb type B on that third party device, and if not, how else this communication can be achieved?
According to the user guide, p9:
When connected to a mini B plug, the AT90USB operates as an “USB device” (the ID pin of the plug is unconnected) and when connected to a mini A plug, the AT90USB operates as a “USB host” (the ID pin of the A plug is tied to ground).
So yes, the board can operate in host mode so long as you use a USB-OTG cable to ensure correct setting of the ID pin.
