You don't need to change the clock rate that high (and it certainly wouldn't be supported by the card). You simply need to adjust Fi and Di, indeed.
Here is an extract from the ISO7816-3 spec:
To reach ~115200 bauds, typically, you'll choose Fi=512 (F=9) and Di=32 (D=5). This, with the same clock of 3.58MHz, will give 111875 bauds. For exactly 115200 bauds, you then need to set the clock to 3.6864MHz, but you certainly don't need to be that accurate. Note that the maximum clock rate that can be supported by the card depends on F and is indicated in the table, too (5MHz for F=9).
Now, in order to adjust Fi and Di, you need to send a PPS (Protocol Parameter Selection) request to the card (see chapter 9 of the spec). For example, you just send FF10957A
to negociate T=0, F=9, D=5. Here is the meaning of each byte:
FF
(PPSS) identifies a PPS request
10
(PPS0) indicates that PPS1 is present and requests T=0
95
(PPS1) requests F=9 and D=5
7A
is the XOR checksum
If the card accepts the request, it will acknowledge it by resending the exact same bytes back, and then change its baud rate.
Note that the maximum F and D values that the card can support are given in the ATR, (in the TA1 byte) so you know what you can negociate.
