Although some packages vary slightly from one-another, nearly all of them have the same PCB footprint and schematic symbol.
How do you guys actually make the footprint, for say, an LM317 TO-220 when it is not (at least by default) in the library?
I assume from scratch as I cannot see a "copy from another item" feature at least on hand, however that opens to major problems if one was done wrong.
I have heard of a default template library of most package types, that'd be amazing to use, however have not found it (or on search engines at first look) nor would I understand how to copy just (i.e. a TO-220 generic) template out and edit it in to my own library.
Any advice on what to do?
I may need to get a lot more proficient at this, as many parts I come across simply do not have libraries. I thought Element 14? (who bought cadsoft I believe) would have made a huge library with every one of their parts - that'd be amazing, again, no luck in search engine and am not even sure it is better than just DIY symbols.
The library you are looking for is named 'ref-packages'.
  • \$\begingroup\$ You will probably find this question and their answers useful, too: electronics.stackexchange.com/questions/27236/… \$\endgroup\$
    – PetPaulsen
    Mar 17, 2012 at 8:04
  • \$\begingroup\$ Easy to pass when there are so many filler libraries that are default, thank you PetPaulsen. Hopefully this question turns a few people looking for "eagle library templates" to the right answer, as I could not find in Google. :) \$\endgroup\$ Mar 17, 2012 at 8:04
  • \$\begingroup\$ I guess no schematic symbols along with it, oh well, very simple to make as I go along. \$\endgroup\$ Mar 17, 2012 at 8:09
