Let's assume I have a memory block here, I didn't set any value to it, what value would it output?
If two outputs from two different bytes meet in the same wires, what happens? I'll give an example: Byte 1: 0101 0100 Byte 2: 1001 0111
Look at the following bus:
(R1 through R5 are registers, s = set, e = enable)
Let's say we have set the enable of both R1 and R2 to 1, will the two bytes from R1 and R2 meet in the same wires? (Look at my question no.2)
Couple of notes:
This is not homework, I've been reading a book about this subject and it didn't explain that stuff.
I couldn't find anything else that explains this stuff.
I know it is suggested to divide my question into 3 questions, but since each one of them is very simple enough and each of them depends on the other questions I didn't see how to do it,
