I have to use a linear actuator in my project and according to my need and availability I found this Linear actuator MEGAMAT2. This requires 24 V supply. enter image description here
But I am unable to understand the pin configuration diagram provided by dealer enter image description here
I think yellow, green and black are for moving forward and backward at full stroke speed and also red, white, blue are for controlling the speed of stroke. But I am still struggling with this pin diagram. Please help about this issue.
  • \$\begingroup\$ Product datasheet should explain all these. \$\endgroup\$ – soosai steven Jan 25 '17 at 18:41
    \$\begingroup\$ It looks to me as though the yellow/green pair directly drives the motor and the rest is probably connect to an internal quadrature encoder ("Puls" ... ?) to tell you how far the actuator has moved. \$\endgroup\$ – brhans Jan 25 '17 at 19:01
