I've been wondering if there is any way to eliminate voltage drop in a diode?
If there is not, what could I use to replace the function of the diode without any voltage decrease?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityI've been wondering if there is any way to eliminate voltage drop in a diode?
Look for "Active diode" circuits that use a FET for the series element. These can have very low voltage drop.
There is no such thing under room temperature conditions. You can make an almost perfect signal rectifier - supplying a voltage from an external power supply that mimics a rectified version of the input voltage. You can also switch a very low resistance device such as a large MOSFET, but it will still have some resistance and thus some drop if current is flowing.
There is also physics-experiment type asymmetric behavior possible in certain superconducting structures at < 2K, but that's not exactly practical. See for example Controllable Disorder in a Hybrid Nanoelectronic System: Realization of a Superconducting Diode in Nature. The paper does not describe a working device, only an avenue that may be followed to develop such a device in the future.
