BACKGROUND
This is my first question on Stack Exchange so apologies for any missteps. I'm currently working on a project measuring tilt outputing an analog signal that ranges from -2V to 2V. But the device I'm using has a precision of up to 1mV. I am looking for a way to measure the analog signals without losing accuracy.
SOLUTIONS I HAVE TRIED
I tried using a resistor divider network as a level shifter. enter image description hereI soon discovered that the capacitor in my ADC chip (MPC3008) pull the voltage down so I added a unity gain buffer using a rail to rai op amp (MCP6281). I connected the ADC as shown on the Adafruit page and using the 3.3V as supply. This solution only works to about 10mV.
I also tried some other various level shifting circuits like the ones suggested here but the op-amp seemed to be affecting the accuracy of the signal by pulling up the voltage.
I only have a unipolar power supply to work with also.
QUESTIONS
  • Are there any ADCs that take an input range of +/- 2V which are compatible with the Raspberry Pi
  • Would a chip would more resolution make it better? Although the problem seems to be my analog circuitry
  • Any suggestions for an accurate level shifting circuit as most of the ADC seem to only take positive inputs
  • The analog signal comes from a BNC cable. I have found a BNC to Monoplug Adapter and a USB Audio Sound card. Would that do the job?
  • Lastly, the solution I tried that gave me accurate readings to 10mV had some random fluctuations, when averaged over 30 seconds, it was fine but is there a way to reduce the fluctuations in readings. A capacitor at the input to the ADC perhaps?
Thanks in advance for any suggestions
  • \$\begingroup\$ Does DC offset matter? i.e. if I said "I shifted this whole signal to a positve voltage range, but I can't tell you by how much that was", would it still work for you? By the way, your question is pretty well-asked, so thanks for asking! \$\endgroup\$ Jan 27, 2017 at 9:27
  • \$\begingroup\$ I am not quite sure what you mean by "compatible with the rpi". Since it has a lot of gpio pins, it should be able to speak about every digital protocol any low speed adc out there can offer. \$\endgroup\$
    – PlasmaHH
    Jan 27, 2017 at 9:42
  • \$\begingroup\$ The USB sound card solution will probably be AC-coupled and therefore not capable of measuring DC signals. \$\endgroup\$
    – pjc50
    Jan 27, 2017 at 10:14
  • \$\begingroup\$ @MarcusMüller If I understand your comment correctly, the DC offset would matter as I need to be able to work out the original signal value before the level shifting. And thanks! \$\endgroup\$
    – Baba
    Jan 27, 2017 at 10:29
  • \$\begingroup\$ @PlasmaHH I don't have much experience with digital protocols so I wasn't sure if there were any restrictions. Thanks for pointing that out! \$\endgroup\$
    – Baba
    Jan 27, 2017 at 10:30
The MPC3008 has a resolution of 10 bits hence, for an input span of 4 volts, the smallest resolvable increment is 4 mV. Then there is its accuracy in terms of DNL and INL (quoted as 1 LSB for each on the front page of the data sheet). 1 LSB means that anywhere in the input range there could be a converted error equivalent to 4 mV so that's 8 mV error due to DNL and INL.
Offset error accounts for another 1.5 LSBs and gain error is 1 LSB.
All in all, if you could accurately reposition your input range to suit the MPC3008 you would have a basic inaccuracy of 4.5 LSBs worst case. This, when related to the original signal means a dependable accuracy of 17.6 mV in a 4 volt span.
So you have to look for something much better and it will probably be 16 bits resolution and have an input capable of dealing with a range of inputs centred about 0 volts. Maxim and ADI strike me as your best bet. They both have good search engines. Also try TI and Linear Technology.
If you can't find a suitable chip (and there will be a few I'm sure) then level shifting is an option and 1 mV accuracy poses no problem at all to a lot of modern op-amps however, use of a negative supply could be advantageous in some cases.
  • \$\begingroup\$ Thanks for breaking down the bit errors! Didn't realise the ADCs had built in errors. DO you think this will do LTC1867LA farnell.com/datasheets/… It is relatively expensive so I don't want to get it wrong. Offset Error = 64LSB, Gain Error = 64 LSB, INL = 4LSB, DNL= 3LSB. Worst case is 135 LSB which is about 7mV. Where do the Gain and offset error come into place? The seem quite large \$\endgroup\$
    – Baba
    Jan 27, 2017 at 11:57
  • \$\begingroup\$ That one is fine if you reserve two channels for zero volt and a stable ref voltage. That way you'll be able to eradicate most errors by sampling signal, zero and ref and compensating in software. \$\endgroup\$
    Jan 27, 2017 at 13:24
  • \$\begingroup\$ Thanks! Don't quite get what you mean by reserving "2 channels for zero volt and stable ref voltage" (As a newbie not sure whether to keeps asking questions here in the comments section or raise a new question. Thanks Again!) \$\endgroup\$
    – Baba
    Jan 27, 2017 at 14:11
  • \$\begingroup\$ You linked to an ADC with multiple inputs right? If you look at the data sheet you will see that offset error match is only 2 LSbs so, immediately, you can benefit by feeding 0 volts to a spare input and, when you read it, that digital value tells you how much the offset error (64 LSb) is of your actual signal to an accuracy of 2 LSb. Does this make sense? \$\endgroup\$
    Jan 27, 2017 at 14:15
  • \$\begingroup\$ Ah I see makes perfect sense! Does the stable ref channel do the equivalent for the gain error match? If is there an equivalent way of finding out the gain error? \$\endgroup\$
    – Baba
    Jan 27, 2017 at 14:49
