Hello I planned a light sensitive one pulse activated switch to know when water tank is completely filled and to turn the water pump off using a relay until I reset the circuit using its N/C Switch.
NOTE: There is an external circuit to detect if water starts to overflow through overflow pipe and turns a Red LED on to make this light sensor circuit detect it.
Light sensitive part is working fine, but the problem is when I supply power to the circuit, Relay 2(RL 2) I mentioned in this circuit diagram keeps turning on and off continuously and I hear its extremely fast continuous switching sound like a damaged speaker. Relay 2(RL 2) will die if it turns on and off in such speed. (The purpose of RL 2 here is giving continuous current to the RL 1 to act as a one pulse activated switch.) I want to keep Relay 1(RL 1) turned on even light turns off and only to be turned off when I reset the circuit.
What changes can I do for this circuit to keep the Relay 1 (which activates by a light falling on LDR) on until I reset circuit using N/C Push Switch?
Thanks in Advance.
