I want a function to go at specific memory location of Flash and I am not able to figure it out.
Do I need to do modification in Linker File?
Also, I have idea that in GCC, I would use #pragma directives by which I can put my code in specific section but don't know how to assign that section to specific address.
I am using Keil and programming LPC2138.
To put a function in a section with GCC, use a function attribute
extern void foobar (void) __attribute__ ((section ("bar")));
Then, declare a section called bar in your linker script. Eg.
MEMORY
  FLASH (rx): ORIGIN=0xDEADBEEF, LENGTH=0x80000000
SECTIONS
  .bar:
    KEEP(*(.bar))
  } > FLASH
| improve this answer | |
