I've wrote a program to run the UART on a custom board, using the the atmega328p only with the internal oscillator, here is my code :
#define F_CPU 1000000UL
#include <avr/io.h>
#include <util/delay.h>
#define BAUD 9600
#define MYUBRR    F_CPU/16/BAUD-1
void init_uart(unsigned short uValue  ){
    // setting the baud rate
    UBRR0H =(unsigned char)  ( uValue>> 8);  // 0x00
    UBRR0L =(unsigned char) uValue;  // 0x0C
    // enabling TX & RX
    UCSR0B = (1<<RXEN0)|(1<<TXEN0);
    UCSR0A = (1<<UDRE0);
    UCSR0C =  (1 << UCSZ01) | (1 << UCSZ00);    // Set frame: 8data, 1 stop
int main (){
    init_uart(MYUBRR);
    DDRD |= (1<< PD7);
    for(;;){
        PORTD ^= (1<< PD7);
        UDR0 = 'k';
        //_delay_ms(500);
    return 0;
I've set the register values based on the examplein the datasheet page 241. the problem that I have is, that I'm not receiving the word correctly, here's what I get :
So any idea what I'm missing here ?
thanks in advance !
  • \$\begingroup\$ How is your custom board connected to the PC? \$\endgroup\$ – DigitalNinja Jan 30 '17 at 19:15
  • \$\begingroup\$ I'm using the FTDI breakboard \$\endgroup\$ – Engine Jan 30 '17 at 19:19
  • \$\begingroup\$ Your code is close to these tutorials but I would try one and see if it works. Then you can customize it, if needed, to make it your own. hekilledmywire.wordpress.com/2011/01/05/… bennthomsen.wordpress.com/arduino/peripherals/… \$\endgroup\$ – DigitalNinja Jan 30 '17 at 19:39
  • \$\begingroup\$ I've been there , the guy is using 16Mhz crystal I've change it 1Mhz but still have the same problem \$\endgroup\$ – Engine Jan 30 '17 at 19:48
  • \$\begingroup\$ If it's not your AVR code then double check your FTDI connections and configuration, and your Putty COM port settings. \$\endgroup\$ – DigitalNinja Jan 30 '17 at 20:04
I solved it. I had to wait on the transmitter and receive flags here the working code :
#include <avr/io.h>
#define BAUD 9600
#define MYUBRR    F_CPU/8/BAUD-1
    // setting the baud rate  based on the datasheet
    UBRR0H =0x00;//(unsigned char)  ( uValue>> 8);  // 0x00
    UBRR0L =0x0C;//(unsigned char) uValue;  // 0x0C
    // enabling TX & RX
    UCSR0A = (1<<UDRE0)|(1<<U2X0);
unsigned char USART_Receive( void )
    /* Wait for data to be received */
    while ( !(UCSR0A & (1<<RXC0)) )
    /* Get and return received data from buffer */
    return UDR0;
void USART_Transmit( unsigned char data )
    /* Wait for empty transmit buffer */
    while ( !( UCSR0A & (1<<UDRE0)) )
    /* Put data into buffer, sends the data */
    UDR0 = data;
int main (){
    init_uart(MYUBRR);
    DDRD |= (1<< PD7);
    for(;;){
        PORTD ^= (1<< PD7);
        USART_Transmit('x');
        USART_Transmit('l');
        //_delay_ms(1000);
    return 0;
