I am designing a small and compact measurement device housing an arduino and breadboard.
I have a number of small electronic PCB's and components I would like to house securely inside and I was wondering if people can recommend ways to secure them so they don't rattle about inside.
The case is made from plastic and 3D printed.
I want the components to be removable in the case of fault or replacing, so I was considering velcro as an option.
Any better ideas would be much appreciated.
  • \$\begingroup\$ Why don't you use screw ? Nylon screw are more or less soft and won't damage much your plastic housing. \$\endgroup\$ – zeqL Jan 30 '17 at 21:15
  • \$\begingroup\$ Standoffs come in metal threaded and plastic for MOBO's which can also be glued in place with Polyurethane construction subfloor adhesive. \$\endgroup\$ – Tony Stewart Sunnyskyguy EE75 Jan 30 '17 at 21:44
  • \$\begingroup\$ I've thought about nylon screws, however I want the device to be compact so the base is filled with the arduino and breadboard and remaining space on the side walls hence why I was thinking to velcro strap it inside. I suppose nylon screws could work, but I just don't really want bits sticking out/inside the finished product. \$\endgroup\$ – Adam Jan 30 '17 at 21:52
    \$\begingroup\$ The first thing to come apart will be the breadboard. \$\endgroup\$ – Nick Alexeev Jan 30 '17 at 22:07
    \$\begingroup\$ Design the 3D printed case with location grooves to hold the boards. \$\endgroup\$ – Brian Drummond Jan 30 '17 at 22:38
If you have a 3D printed box I suggest that you re-design the 3D data set to include printed in standoffs on the inside of the box that match the board mounting holes. These standoffs can be designed with a center hole in them so that you can mount your boards with short self taping screws.
Such standoffs would look similar to this one from a standard molded plastic enclosure.
After all, 3D printing is all about customization - make use of it.
| improve this answer | |
Anything really. Most of the time it amounts to including a hole in the board.
Technically double sided sticky tape and velcro are not ESD safe and should not be used in a real design, but if your a hobbyist it probably wouldn't matter.
Some things that I've used:
Zip ties - Just measure the zip tie and put a hole of appropriate size in the board
Standoffs and mechanical fasteners enter image description here
PCB card guides:
