As the internal resistance (or input impedance) of a multimeter influences the circuit you are measuring, and therefore influences the accuracy of your measurement, it would make sense to me to if this internal resistance were mentioned somewhere in the multimeter spec sheet.
When multimeters used physical d'Arsonval movement "galvanometer" where a typical industry standard developed around 50 µA for full-scale deflection, that was all the user needed to know. Regardless of current range, 50µA would flow through the galvanometer and the remainder through the shunt resistors.
For example, when measuring DC current through a low resistance load, a couple of Ohms internal resistance can make a big difference, so it would be helpful to know at least its order of magnitude.
However, although some manufacturers (e.g. Fluke) specify the input impedance for voltage measurements, I have not been able to find similar specifications for the current measurement part (e.g. the ammeter internal resistance or shunt resistor values for different measurement ranges).
I know how to measure the ammeter resistance using a load in series and resistors (or decade box) in parallel with the multimeter, but I don't understand why manufacturers do not provide these values in their spec sheets.
Does anyone know? Am I missing something obvious? Am I looking at the wrong specification perhaps?
As electronic DMMs replaced d'Arsonval galvanometer, it took time for the industry to determine how to represent the equivalent effect. Eventually they settled on the term 'burden voltage' to convey equivalent information.
    \$\begingroup\$ You are probably looking at the wrong place, almost all good multimeters I had in my hands had their burden voltage specified somewhere \$\endgroup\$
    – PlasmaHH
    Jan 31, 2017 at 11:19
  • \$\begingroup\$ If you've paid less than 10$£eur for your meter, don't expect to find a voltage burden in the specs, if you have any specs at all that is. But you can measure it, with another meter! \$\endgroup\$
    – Neil_UK
    Jan 31, 2017 at 12:06
  • \$\begingroup\$ Thanks @PlasmaHH, burden voltage, apparently that's what I was looking for. \$\endgroup\$
    – Laarmans
    Jan 31, 2017 at 12:33
  • \$\begingroup\$ @Neil_UK: what about a 200$£eur meter? Cannot find much info there either. \$\endgroup\$
    – Laarmans
  • \$\begingroup\$ paying more than $10 is necessary, but not sufficient. \$\endgroup\$
    – Neil_UK
    Jan 31, 2017 at 13:18
Burden Voltage
What is Burden Voltage? One thing we rarely look at is the effect we have on a circuit when we attempt to measure the current flowing through it. In this case, the act of inserting the dmm 'A' or 'mA' input shunt in series with a current loop can significantly reduce the actual current flowing in the circuit. If the source voltage in the loop is very high, or the loop is current regulated, then the effect is minimized, but when you are operating in a circuit using a pair of AA batteries in series as a power source, you have only 3 volts to play with, and the shunt of a dmm's mA input can present a significant circuit loading error if you fail to account for it's effect.
So how much effect does the current shunt present? There is a little used specification in the user manual that can help you figure that out – it's called Burden Voltage, and once you know how to use the information, you can make corrections to your measurements to compensate for the effect.
- Fluke 77IV user manual
  • \$\begingroup\$ Thanks for the quick response! This is exactly what I was looking for. Cannot seem to find any burden voltage spec in the Fluke 115 manual though. \$\endgroup\$
    – Laarmans
    Jan 31, 2017 at 12:27
