I am choosing an over-voltage protection diodes for input pins to a device. There will also be spark gaps on these lines.
My question is what kind of effect will the leakage current of the diode have on the power supply. I have already read that for battery supplies the battery life can be affected / reduced.
The leakage current of diodes produces a constant current flow. It's defined for conditions where the diode is not actually in conducting state. Thus, these diodes rise your total power consumption like a parallel resistor. Normally this current is very low, we are talking about \$nA\$ or \$\mu A\$. However, this values depends on your type of diode and e.g. the clamping voltage of TVS diodes. In generally, it's defined in the datasheet.
  • \$\begingroup\$ Ah I was being dumb and thinking that leakage was flowing into the supply, but it actually flows in the reverse direction.. makes more sense now. \$\endgroup\$
    – GodJohnson
    Feb 1, 2017 at 15:02
