I am working with an ARM Cortex M3 chip (reference manual available here). I'm trying to get the baud rate of my USART communications right. Reading pages 613 onwards, I understand that the value I should set for USARTDIV depends on the clock rate of AHB1 (since I am working with USART3, governed by the AHB1 clock).
Looking at pages 614 onwards, I see that the clock rate f_PCLK can take many different values (8MHz, 12Mhz, etc.). However, I cannot see anywhere where I can set the speed of that clock.
How can I measure/change/read the speak of the AHB1 clock?
Page 83 of the reference manual has a clock tree diagram. This will help you see where the clocks come from.
The PCLK is a peripheral clock and will depend on the clock source and the prescaler values. The AHB, APB and other prescaler values are set in the system_stm32f2xx.c file.
  • \$\begingroup\$ Thanks! Do you understand what the line __I uint8_t AHBPrescTable[16] = {0, 0, 0, 0, 0, 0, 0, 0, 1, 2, 3, 4, 6, 7, 8, 9}; exactly means? \$\endgroup\$
    – Randomblue
    Commented Mar 20, 2012 at 16:20
  • \$\begingroup\$ It's an array that is used to set the SystemCoreClock variable. Search for both AHBPrescTable and SystemCoreClock and you should be able to figure out what's going on. \$\endgroup\$
    – Armandas
    Commented Mar 20, 2012 at 16:29
  • \$\begingroup\$ @Armandas, I know this is an ancient topic, but could you describe how AHBPrescTable is indexed, I'm finding the code impenetrable. Thanks! \$\endgroup\$ Commented Oct 17, 2019 at 11:24
  • \$\begingroup\$ @RichardWhitehead I don't get your question. What do you mean by "indexed"? \$\endgroup\$
    – Armandas
    Commented Oct 18, 2019 at 2:13
