I have the question "Two resistors of resistance, 3 ohms and 6 ohms, are connected in parallel across a battery having a voltage of 12V."
I am asked to determine the total circuit resistance. Here is my attempt is this correct ?
It then asks me to find the current flowing in the 3 ohm resistor using the answer above. For which I got:
V = IR
Therefore , I = V/R
Therefore,
I = 12/2 = 6A
Is this correct also ?
Yes, your answers are 100% correct.
If you want to do a bit of a cross check, calculate the current through each resistor individually and add them.
Yes, both answers are correct.
