I'm trying to build an ultrasonic transmitter circuit. The datasheet specifies 20V peak-peak for the ultrasonic to operate at its maximum power. However I'm limited to only using a 9V supply. What I thought about doing is making an H-Bridge to switch the polarity of the battery between 9 and -9, giving me almost 18vpp. Do you think this is a good idea? Do you have anything else to recommend?
This is what the circuit would look like. Function generator simulates a 40kHz square wave, scope is there just to look at the output.
  • \$\begingroup\$ Are you using a separate transducer for receiving echoes? \$\endgroup\$ – Nick Alexeev Feb 5 '17 at 21:34
  • \$\begingroup\$ Typically you would have three levels: +9V, 0V, -9V. \$\endgroup\$ – Tom Carpenter Feb 5 '17 at 23:17
Why re-invent the wheel when you could just use the same method used by the HC SR04 using an RS232 Tx to run the sender.
Ultrasonic emission sources somewhat behave and work the same way as speakers or buzzers. Using a [-Vcc to Vcc] range (with a H-Bridge) is a common practice in class D audio amplifiers to double the peak-peak voltage across the membrane. So that's all right!
