-1
How can one validate the data/contents read from memory[eeprom/flash] is correct or not?
What i have done is,
1.) read_mem(location, readBuf1,128)
2.) read_mem(location, readBuf2,128)
3.) if 0 == memcmp(readBuf1,readaBuf2,128), then VALID else INVALID
What are Pros and Cons of above steps?
Any another ways to do it?
  • \$\begingroup\$ Is this an academic assignment? \$\endgroup\$ – Nick Alexeev Feb 6 '17 at 5:37
If the contents ot the memory are corrupted, reading them twice won't help. The usual method to validate memory contents is using additional data like checksum or CRC
If reliability is an issue, one can use a flash memory that has builtin checksums. 32 MB flash with ECC
Simple redundancy is NOT a good test; if a data bit were stuck high or low, it would pass that test. At least, invert the bits.
