Whenever I'm making a cheap, 2-sided PCB, I run into this problem:
Where I have signal lines (on the top layer here) running over top of a big fat power trace (on the bottom layer).
Now, this is obviously terrible because there is no good return path on the bottom side. For issues like this, Hott consultants has a good recommendation:
However, I wonder if a solution like the one below is also acceptable.
My intuition tells me yes, this solution is ok. Over the break in the ground plane, the current will hop over the vias and then back down to the lower plane. Some back of the envelope math tells me that this adds a trivial amount to the loop area, and therefore a trivial amount to the return impedance.
Can someone tell me...
- How right / wrong my intuition is here about using vias?
- If my intuition is wrong, why?
- Also, if my intuition is wrong, what is the correct solution in this sort of situation (2 layer, with power traces under signal)?
For the record, these particular signal lines aren't terribly fast (500 kHz), but I would like to know how to deal with this situation when I have signals in the 5 - 10 MHz range.
Edit
Below is a screenshot of about 60% of the board. Maybe it will help with the critique
