I have an MCP4725 12 bit DAC from Sparkfun and i am trying to interface it with raspberry pi 3
Connections :
Vcc -> 3.3V/5V of Rpi
Gnd ->Gnd of Rpi
scl and sda -> to scl and sda of rpi
out -> to DMM
and I tried to run this code: ADAFRUIT
What else i tried :
I tried to short addr pin with vcc and then with Gnd
I also tried to cut the tracks from pullups thats are given on the back side of the board Problem
Even though I tried the connections ,The circuit does not seem to work .
Questions :
1)Is it possible to interface MCP4725 with Rpi ?
2)do I need to use level shifter for I2C pins ?
  • \$\begingroup\$ According to your URL: 1) Yes, 2) No \$\endgroup\$
    – Wesley Lee
    Feb 6, 2017 at 8:39
  • \$\begingroup\$ What is the connection for A0. You might be missing the address part. What is theI2C address of DAC you have configured for?. You didn't mention your problem. The interfaces are fine. Interfacing is obviously possible as the link is for the same from adafruit. No level shifters are necessary. \$\endgroup\$
    – User323693
    Feb 6, 2017 at 8:39
  • \$\begingroup\$ @Umar Well, there is no A0 pin on the board that I have I just have I2C pins. \$\endgroup\$
    – Mr.Sky
    Feb 6, 2017 at 8:43
  • \$\begingroup\$ Definitely do NOT cut the tracks to the pullup resistors! You do know how i2c works, right? \$\endgroup\$
    – John M
    Feb 6, 2017 at 8:44
  • \$\begingroup\$ what is the answer for my another question? what is the I2C address of DAC? \$\endgroup\$
    – User323693
    Feb 6, 2017 at 8:45
  1. Yes, you can use MCP4725 with rpi.
  2. Yes, IF you power your MCP4725 with 5V0.
  3. The devices addresses are 0x62/0x63 for A0 = 0/1
  4. The on board pull up resistors are 4k7. You need to remove them IF you have too many other I2C devices connected.
