This is a generic concept question that I encountered during the first day of an EE course. Our lecturer told us that electric circuits are essentially electric networks with closed loops.
I would like to know how an electric network with an open loop works. Is it referring to an open circuit where nothing really works or are there actually functioning networks without closed loops? And if such networks exist, how is energy transferred and how does KVL work in that case?
  • \$\begingroup\$ Your radio has an open loop between antenna and earth. It draws energy from EM waves floating all around us. KVL doesn't work at all for that case, you had to replace antenna and earth by a HF AC source in your mind first. \$\endgroup\$ – Janka Feb 6 '17 at 9:25
  • \$\begingroup\$ Some examples of electricity (like, putting a static charge on a balloon by rubbing it in your hair) are not well-described by circuit terms. Mainly, though, useful applications are circuit-based. \$\endgroup\$ – Whit3rd Feb 6 '17 at 11:06
I think that the lecturer uses an arbitrary definition of electric circuit. For many authors electric circuit is a synonym of electric network, this latter term being sometimes used for more complex circuits or circuits that are bigger in extent.
Unless he said something wrong, he is using a possibly non-standard definition, so you should ask him directly.
Maybe his statement was put in a context that may give a better understanding of what he meant, but if taken at face value, his statement is nonsense: KVL can be applied only if there are loops in a circuit. A network with no loop is a degenerate circuit, with no useful property.
Currents can circulate in a network only if there are closed loops, otherwise there is no current, hence no power transfer whatsoever.
Of course this assumes we are talking about basic circuit theory, where every network is assumed to be a lumped element network, and no electromagnetic phenomenon happens outside those little black boxes that we call components.
If we are talking about more general electrical "circuits", i.e. circuits where Maxwell's equations cannot be neglected, the same concept of circuit is somewhat blurry.
What the lecturer teaches you is probably passive circuit theory, and this class is aimed at providing you with the mathematical techniques to analyse passive circuits (KVL, KCL etc.). The intuition you attained from studying this course will help you greatly with analysing real circuits.
To come to your question, it depends. When looking at DC circuits, yes you need a closed loop for current to flow. However, when you look at AC signals, energy can escape from a wire (antenna) and propagate through space.
