I am trying to display a variable in an LCD. I am using a PIC18F4550 and I am compiling with XC8. My code is the next:
#include<pic18f4550.h>              //----Include Reg file of Pic18f4550
#define lcd PORTD                   //----Assing PORTD as lcd
#define rs PORTCbits.RC0            //----Register Select Pin for Control of LCD
#define rw PORTCbits.RC1            //----Read/Write Pin for Control of LCD
#define en PORTCbits.RC2            //----Enable Pin for Control of LCD
#include "lcd.h";
#include "stdlib.h";
//////////// Main Program //////////////////////////////////////////////////////
void main()
    DDRD = 0x00;                    //----Set as output
    DDRC = 0x00;                    //----Set as output
    lcd_init();                     //----Initialize LCd
    char k = "p";
    while(1)                        //-----Creating Super Loop
        lcd_cmd(0x80);               //----- First row in LCD
        lcd_msg("LCD Display"); //-----Data
        lcd_cmd(0xC0);               //-----Last lacation of 1st Line
        lcd_msg("Variable:");
        lcd_msg(k);
        delay(250);                 //-----250 msec delay
and I am using the next lcd.h header:
////// Proto-Type Decleration //////////////////////////////////////////////////
void lcd_cmd(unsigned char x);      //----Function to Send Command to LCD
void lcd_dwr(unsigned char x);      //----Function to Send Data to LCD
void lcd_msg(unsigned char *c);     //----Function to Send String of Data to     LCD
void lcd_lat();                     //----Function to Latch data into LCD
void lcd_ready();                   //----Function to Check LCD is Busy
void lcd_init();                    //----Initialization of LCD
void delay(unsigned int ms);        //----Delay Function for 1ms
    lcd_ready();                  //----To Check whether lcd is busy
    lcd = x;                      //----8-Bit Command is Send to PORTD
    rs = 0;                       //----Register Select Pin is Low => Command Register
    rw = 0;                       //----Read/Write Pin is Low => Write.
    lcd_lat();                    //----Latch data into LCD
    lcd = x;                      //----8-Bit Data is Send to PORTD
    rs = 1;                       //----Register Select Pin is High => Data Register
    while(*c != 0)              //---Check till last data is send
        lcd_dwr(*c++);          //---Send data to lcd and increment
void lcd_lat()                    //----To Latch data into LCD
    en = 1;                       //----Enable Pin goes high
    delay(1);                     //----delay of 1ms
    en = 0;                       //----Enable Pin goes Low
void lcd_ready()
    lcd = 0xFF;                   //----PORTD is High
    lcd &= 0x80;                  //----D7 is set as high
    rs = 0;                       //----Command Register is Selected
    rw = 1;                       //----Read/Write Pin is High => Read
    en = 0; delay(1); en = 1;     //----Low to High to read data from LCD
    if(lcd == 0x80)
    else
        //---Do nothing.
void lcd_init()
    lcd_cmd(0x38);              //----8-bit data and 16x2 line
    lcd_cmd(0x0E);              //----Cusor Blinking
    lcd_cmd(0x01);              //----Clear LCD
    lcd_cmd(0x06);              //----Increment Cusor
    lcd_cmd(0x80);              //----1st low of 1st row
    unsigned int i,j;
    for(i=0;i<=120;i++)         //---To generate 1ms delay
        for(j=0;j<=ms;j++);     //---To generate user define delay
But I am not capable to display the character "p" enter image description here
I am new on pics. I would appreciate any suggestions, thanks
  • \$\begingroup\$ Are the other parts of your LCD code working? Is it just the variable that isn't being displayed? If so, is it displaying anything for the variable? A char is just a single character, so you should assign it like this char k = 'p';, using single quotes. Double quotes are for strings. \$\endgroup\$ Feb 7, 2017 at 1:26
  • \$\begingroup\$ Yes, the other parts are working, I can even create and display special characters. I tried to use single quotes too. But I obtain the same result as the image I uploaded \$\endgroup\$
    – Nau
    Feb 7, 2017 at 1:37
  • \$\begingroup\$ It looks like lcd_msgwants a char*. If you want to display a single character try using lcd_dwr instead. So keep char k = 'p'; (single quotes), and call lcd_dwr(k); instead of lcd_msg(k);. \$\endgroup\$ Feb 7, 2017 at 2:00
The problem is that the lcd_msg() routine wants a char *, but you're passing it a single char instead. You could either turn your variable into a NUL terminated string like this:
char *k = "p";
//  other code
lcd_msg(k);
Or you could display a single character like so:
char k = 'p';  // note use of single quotes for single char
// other code
lcd_dwr(k);
