Attached the LTspice curve result of the monte carlo simulation. enter image description here How can measure the minimum value from the curve. Here it show only the middle values while measuring. What setting change should be done.
    \$\begingroup\$ With a .meas min statement? \$\endgroup\$ – PlasmaHH Feb 7 '17 at 9:09
If you press the up down keys you can select different curves.
A .meas statement could also do this but I haven't tried it personally with a .step simulation.
You can export files if lt spice won't give you the information you want.
Not the answer you're looking for?Browse other questions tagged or ask your own question.
