As the title states, I would like to know if a battery charger for AA NiMH batteries could be used to charge also AAA, C and D battery types (all of which also of NiMH type).
I am aware of that physically they won't fit in, therefore I would need to connect them with wires. I am asking more voltage and charging algorithms wise. Would it damage the batteries or would the charger get damaged itself? Why?
I think all of them are of same voltage.
Thank you!
closed as off-topic by Marcus Müller, Dmitry Grigoryev, Voltage Spike, ThreePhaseEel, nidhin Feb 8 '17 at 12:01
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Marcus Müller, Dmitry Grigoryev, Voltage Spike, ThreePhaseEel, nidhin
If this question can be reworded to fit the rules in the help center, please edit the question.
You need to consider their current handling capability as well. This increases in order AAA AA C D.
It is safe to charge a higher capability cell from a lower capability charger.
So you will be able to safely charge AA C and D.
AAA may be able to be charged by the same charger but you need to check the specification of the battery and the charger, checking that the battery can tolerate the charge current provided by the charger.
There is a good article on NiMH charging here http://www.powerstream.com/NiMH.htm
  • \$\begingroup\$ Thank you for your answer. In this scenario, I consider using wires to connecting the batteries to the charger as not risky even without presence of any thermistor. Am I right? \$\endgroup\$ – quaeched Feb 7 '17 at 10:20
  • \$\begingroup\$ I cant answer that without knowing the type of charger. Some do use temp increase to indicate end of charge. Slow chargers where the current is less than 1/10 of capacity should be safe. \$\endgroup\$ – RoyC Feb 7 '17 at 11:13
  • \$\begingroup\$ I thought that based on the small relative capability when moving from AA to C or D. Thank you. I will try it and when something comes up, I will make an update. \$\endgroup\$ – quaeched Feb 7 '17 at 12:10
  • \$\begingroup\$ I can confirm it works. I tried it and the outcome was satisfying. Thank you. \$\endgroup\$ – quaeched Feb 13 '17 at 10:45
