I've got a question about something I don't understand that is going on in my FPGA project. I need to control two devices (AGC and ADC) through an SPI bus. As as the FPGA will be the master device, I'm generating a clock signal, SCK, in code by dividing the system clock. I then rout that signal to an output wire through a tristate buffer. Below is my relevant bit of code. It's not shown, but the signal that controls the tristate buffer, en_SCK controlled by a FSM, when it is set low in the idle state and then high for the rest of the states.
output wire SDI
//for SCK_clock
reg SCK_gen, SCK_hold;
integer i;
reg en_SCK;
wire neg_edge_SCK;
//SCK_generator
always @(posedge clk)
begin
i <= i+1;
SCK_hold <= SCK_gen;
if(i == 10)
begin
SCK_gen <= ~SCK_gen;
i <= 0;
end
end
assign SCK = (en_SCK) ? SCK_gen : 1'bz;
When I get implement the design i get the following warning:
WARNING:PhysDesignRules:372 - Gated clock. Clock net en_SCK_not0001 is sourced by a combinatorial pin. This is not good design practice. Use the CE pin to control the loading of data into the flip-flop.
Also I notice my clock seems very distorted. But if I don't use the tristate device in my code and direclty assign the clock signal to the output wire (as in the code below) I get a nice clean clock signal.
assign SCK = SCK_gen;
Below is a side by side of the signal SCK without the tristate buffer (left) and with the tristate buffer (right). I'm fairly new to FPGA and Verilog, but my understanding is that using that style of assign code implies a tristate buffer, so I'm confused why it seems to be interpreted as a gated clock source (The XST generated schematic shows it implimented with an and gate. I'm also confused about how it's distorting the clock signal. The FSM should be forcing the en_SCK enable signal high for many times the period of the clock so I'm not sure what's happening. Also according to the demo board manual, other devices share this signal so I have to set it to high impedance when it's not in use. If someone could point me in the right direction, or explain it to me I'd be very great full. Thanks
Here's a link to my origional question at Stackoverflow.com
Here is the entire Module if that makes things more clear. I've only done a couple of simple Verilog projects before, so I'm sure my code is not great. But I did try to design it using a FSM. Maybe my problem is not what I thought. Thanks for you patience.
module AGC_controller
input wire clk, reset, set_AGC, AMP_DO,
output wire SDI, SCK,
output reg inhibit_ADC, AMP_CS,
//spi disable signals ** all disabled for =1 except AD_CONV. When AD_CONV=0, disabled.
output wire DAC_CS, AD_CONV, SF_CEO, FPGA_INIT_B,
output reg [7:0] led
localparam [2:0]
idle = 3'b000,
set_up = 3'b001,
start_data = 3'b010,
wait_for_neg= 3'b011,
wait_4 = 3'b100,
next_bit = 3'b101;
// wait_last = 3'b110;
//signals
//for SCK_clock
integer i;
reg en_SCK;
wire neg_edge_SCK;
initial
begin
SCK_gen = 0;
i=0;
end
//SCK_generator
begin
i <= i+1;
if(i == 10)
begin
i <= 0;
end
end
//detect neg edge of SCK
assign neg_edge_SCK = SCK_hold & ~SCK_gen;
//general signals
reg [2:0] state_reg, state_next;
integer bit_position;
reg [7:0] AGC_buf;
reg en_SDI;
//FSM control
always @(posedge clk, posedge reset)
begin
if (reset)
state_reg <= idle;
else
state_reg <= state_next;
end
//FSM next state logic
always @*
begin
state_next = state_reg;
case(state_reg)
idle:
begin
bit_position=7;
AGC_buf = 8'b10011001;
en_SCK = 1'b0;
en_SDI = 1'b0;
AMP_CS = 1'b1;
inhibit_ADC = 1'b0;
if(set_AGC)
begin
state_next = set_up;
end
end
set_up:
begin
AMP_CS = 1'b0;
inhibit_ADC = 1'b1;
if ((SCK_gen) && (i < 9))
state_next = start_data;
end
start_data:
begin
en_SDI = 1'b1;
if ((SCK_gen == 0) && (i==2))
begin
state_next = wait_for_neg;
en_SCK = 1'b1;
end
end
wait_for_neg:
begin
if (neg_edge_SCK)
begin
state_next = wait_4;
end
end
wait_4:
begin
if (i==4)
begin
//test code to light leds
led[bit_position] = SDI;
if (bit_position == 0)
begin
state_next = idle;
end
else
begin
state_next = next_bit;
end
end
end
next_bit:
begin
bit_position = bit_position - 1;
end
endcase
end
assign SDI = (en_SDI) ? AGC_buf[bit_position] : 1'bz;
assign DAC_CS = (state_reg != idle);
assign AD_CONV = (state_reg == idle);
assign SF_CEO = (state_reg != idle);
assign FPGA_INIT_B = (state_reg != idle);
endmodule
