I am referring to IDT7203 datasheet. ( MEMORY FIFO 2048X9 25NS )
Link here: http://www.digikey.com/product-detail/en/idt-integrated-device-technology-inc/7203L25J/800-2478-5-ND/2014356
My question is this FIFO memory is Volatile or Non Volatile type?
Thanks in advance.
    \$\begingroup\$ Volatile. is there specific doubt or case due to which you are looking for a FIFO with non volatile options? \$\endgroup\$
    – User323693
    Feb 8, 2017 at 5:29
  • \$\begingroup\$ Do you mean IDT7203 is volatile .. It is not mentioned in datasheet, hence confused. \$\endgroup\$ Feb 8, 2017 at 6:04
    \$\begingroup\$ pls see the picture in the answer below \$\endgroup\$
    – User323693
    Feb 8, 2017 at 6:15
While the datasheet may not state that these FIFOs are volatile, their normal use would require a volatile memory, as they will normally be written to frequently, at full processor speeds, like normal RAM.
Non-volatile solid state memory (EEPROM, FLASH) can usually only tolerate a limited number of write cycles, and usually requires special slow operations for writes, so would not be suitable for use in a FIFO.
To answer only the volatile feature of IDT part:
The RAM nomenclature used should help you convince yourself that the part is volatile.
Non volatile write speed are way less than high speed volatile memories. Pls see answer from @peter.
Also, below:
Data is stored in the RAM array sequentially and independently of any on-going read operation
Both from page 1 of the datasheet.
