What is the connector type for this soldering iron?
I am contemplating fitting it to a private-badge version (DSE T-2200) of the same station that doesn't have the connector fitted, so I will have to either remove the connector on the iron and hardwire it like the existing iron, or else butcher a new connector socket into the station, which I probably prefer.
EDIT Maybe I should redefine the question: What panel-mount male socket should I use with this plug?
    \$\begingroup\$ Most likely this is a 5-pin Tuchel connector. See thumbs.picclick.com/00/s/NzEwWDgwMA==/z/RGAAAOSwo0JWJ1Kf/$/… They are similar to DIN connectors but have a wider range of pins angles and feature a shield screw connect \$\endgroup\$ – Janka Feb 9 '17 at 1:48
  • \$\begingroup\$ @Janka So mating to this? A bit bizarre that it's female, not male, nicht war? \$\endgroup\$ – user207421 Feb 9 '17 at 2:55
    \$\begingroup\$ That one should fit the pins but obviously it does not fit the screw. You'd need a sunken type. \$\endgroup\$ – Janka Feb 9 '17 at 3:17
  • \$\begingroup\$ @Janka It isn't obvious to me. Why do you say it doesn't fit the screw? \$\endgroup\$ – user207421 Feb 9 '17 at 4:41
    \$\begingroup\$ The usual female Tuchel connectors have a long metal sleeve covering the female header, so their screw can meet the back-dropped screw of the male connector. The one from the soldering iron does not. I've seen that variant a number of times and it always ended up cutting that stupid connector from the cable because the mating part was not obtainable. \$\endgroup\$ – Janka Feb 9 '17 at 4:47
The connector is a cheaper version of the XLR called an Automotive/Aviation GX16 Series Plug. There may be many manufacturers in China, but here is one: http://www.hzconnector.com/product/60388845390-800546210/Silver_Aviation_Plug_4_Pin_16mm_GX16_4_Metal_Male_Female_Panel_Connector_Pack_Of_5.html
They are very commonly used on soldering Irons and CNC/Stepper motor connections the -4 eg GX16-4 indicates the number of pins. They come in 2-14 pin variants.
You are looking for the B 605 sold for example by Reichelt. This type belongs to extrem robust microphone XLR connectors for professional PA use. If you like use another shop for ordering search for 5-Pin - Ham & CB Radio Microphone Connector - Panel Jack
Reichelt B 605
It's hard to see the exact type used. The housing is very common, but the pin layout is found in many different types.
It looks very similar to this one I have used for multiple projects:
For example Cliff Electronics makes those, it's the Cliffcon Miniature ZC Series (RS: 111-5763)
Sparkfun offers a 6-pin version of these connectors in a pair, the plug and chassis mount connector:
Using these would of course require re-wiring the plug on the end of the soldering iron wand. I mention this choice in case it is easier for you to obtain on-line as opposed to searching out sources for the 5-pin version.
