I have an accelerometer sensor which must be placed 1 m from my microcontroller. I can choose whether to place the ADC near the sensor or the controller.
I understand that longer distances from the sensor contribute more voltage fluctuation pre-ADC (noise). Longer distances from the microcontroller increase SPI errors and limit my transfer rate.
If I need to clock the SPI transfers to 4 MHz, where should I locate the ADC? Will the 1m distance be limiting my transfer rate? Will 1 m of pre-ADC wire contribute significant noise?
Notes:
- The ADC has a 0 – 5 V input range, I care about steps in the 10 mV range (1/500th of the range). If my noise peaks are below that the application will be successful.
- The wires between the ADC and sensor will carry 3 Vout channels, ground, and 5 V.
- The sensor, wires, and (depending on placement) the ADC will undergo impacts as the application is impact characterization. Impacts will be due to dropping with an estimated peak g force of 150 g for 2 ms.
Accelerometer specs
Update: I decided to run the ADC close to the pi (~6 inches) and the sensor far from the pi (~0.75m) as the analog noise sounded easier to troubleshoot than the digital errors. I currently get a baseline of ~61mV from the sensor with a standard deviation of 10mV (based on ADC readings). Peak to trough noise levels are about 60mV. This is a decent start but I think I have some improvements to make in the circuit design. For example, without a sensor attached I get a fluctuation of about 100mV on the scale of 1Hz. I'm going to improve my Vref and grounding scheme and see if I can remove some of this noise. Thus far I don't think my main issue is cabling, though insight is welcome. Also found this useful reference: http://ww1.microchip.com/downloads/en/AppNotes/00688b.pdf
Update:
My final circuit was drastically improved from the first so it will be hard to say exactly what changes were responsible for the improvements. My initial design didn't include decoupling capacitors, a dedicated reference voltage, and also had multiple paths to ground. I eventually designed and got a PCB fabricated for about 20 bucks + shipping. With this system, a 0.75m length of 10 wire IDC cable carrying the analog voltage to the ADC, and IDC connectors here is my result:
The right axis shows the integer output of the ADC. The standard deviation of that variance in y is about 3 units (mV) and in z is about 4.1 units. Peak to trough is about 20 units. This is a huge improvement over the first design and I'm very happy. decoupling capacitors and a reference voltage were critical it seems. Going throught the whole process of getting a board fabricated was super fun as well.
I can't explain the increased variance for the z channel. It is furthest from my power/ground wires. It is the last wire on the end of the flat cable, so that could be it.
