The schematic of Klipsch SW-12 is on Page 15-17 of the following service manual:
http://www.audiolabga.com/pdf/SW12-15%20I.pdf
R87, R88, R89, and R90 get pretty hot.
[The schematic's Sheet 3 with the above resistors highlighted added 2/12/17.]
The schematic indicates they should be all 750 ohm 5W and the originals are 750 Ω 5 W 5 %; however, the service manual's part list indicates that they are 1.5 kΩ 5 W.
One of them reads only 426 Ω (off the circuit), so I'll have to replace it for sure.
Questions:
  1. What would happen if I replaced all of R87, R88, R89, and R90 with 1.5 kΩ 5 W resistors?
  2. If the amplifier operates with 1.5 kΩ resistors, will it run cooler?
[Added 2/9/17]
The four resistors are on Sheet 3 of the schematic, POWER AMP section, left side. The four resistors are vertically aligned.
[Added 2/10/17]
The following resistors do fit and seem to be stocked by distributors in the USA now.
TWM series by Ohmite:
[H x W x L: same as the original; same pin spacing]
5W 750 ohm 5%
5W 1K ohm 5%
5W 1.5K ohm 5%
Datasheet:
http://www.mouser.com/ds/2/303/tww_twm_series-25614.pdf
SQM series By TE Connectivity:
[H is 13 mm greater than the original's, but W and L are the same - will fit; same pin spacing]
7W 1K ohm 5%
Datasheet:
http://www.te.com/commerce/DocumentDelivery/DDEController?Action=srchrtrv&DocNm=1773285&DocType=DS&DocLang=English
MCPR series By Multicomp:
7w 750 ohm 5%
Datasheet:
http://www.farnell.com/datasheets/1679919.pdf?_ga=1.72813905.374067655.1485773361
    \$\begingroup\$ It's a bit unlikely people here will search 3 pages of schematics to find your four resistors. Please at least post a highlighted part of the schematic. Also, what is "pretty hot"? 5 W resistors aren't exactly the most delicate devices when it comes to heat. \$\endgroup\$ Feb 9, 2017 at 22:45
  • \$\begingroup\$ @Marcus Muller: Sheet 3, POWER AMP section, left side. The four resistors are vertically aligned. \$\endgroup\$
    – zeron
    Feb 9, 2017 at 23:39
  • \$\begingroup\$ @Marcus Muller: "...what is 'pretty hot" The one that read 426 off the circuit once got so hot it melted its two leads' solder joints. the other three get hot, too. The spot on the PCB where R87 and R88 (on the other side) are attached to is slightly burned (just dark, not charred). Last time I checked, I didn't want to keep my fingers on them more than a split second. My fingers were not blistered, so at that time their surface temperature was probably not much more than 72 degrees F. \$\endgroup\$
    – zeron
    Feb 9, 2017 at 23:56
  • \$\begingroup\$ @zeron: "...72 degrees F" Typo again: 72 degrees C. \$\endgroup\$
    – zeron
    Feb 10, 2017 at 0:25
  • \$\begingroup\$ The total dissipation of the 4 resistors would be 160V^2/(750x4)=8.5W when idle, a bit more when there are signals. The value might have been chosen for a conservative beta of Q15 and Q24, if that was the case, there is a good chance using 1.5K would have little impact. Try it and turn the volume up and see if you can hear a difference. \$\endgroup\$
    – rioraxe
    Feb 10, 2017 at 2:44
Probably the amp will work either way. It's hard to say which is the intended design, what the schematic says or the BOM says.
One possibility is that this circuit was originally designed with 750 Ω resistors, and these turned out to be problems in the field, so a revision was issued changing them to 1.5 kΩ as a quick fix. This quick fix probably makes the problem go away (the resistors being over-stressed and failing), but may compromise other parameters of the amp slightly. It wouldn't be the first time a company figured a little reduction in performance will be unnoticed, especially if nobody is looking for it, but failed parts are definitely noticed.
Electrically, it looks like lower resistance is better, with the tradeoff being too much dissipation and heating inside the chassis if too low. Whoever designed this originally thought about it enough to spec 5 W parts, but maybe missed how the voltages can vary and/or decided not to look too hard because the answer would have been uncomfortable. Yes, this happens. Not everything is caught in a design review, or even gets a proper one, when a junior engineer sticks his head in the sand.
The right answer for the field bullitin might have been 750 Ω 10 W resistors, but those would have been physically impossible to substitute in the given locations with the existing space and pads.
I would not replace these resistors with 750 Ω 5 W. That's clearly abusing the parts. Ideally that would mean these resistors can take up to 61 V across them, but note the 81 V supplies. They should average to 40.5 V across them, but power doesn't follow the average voltage. The RMS will be higher than the average with large AC signals superimposed.
You could try replacing with 750 Ω and a bit higher than 5 W. Those probably don't fit in the original footprints. The official service bullitin can't recommend flying parts, but you can do that one-off yourself. Getting these resistors away from other parts is probably good too.
1.5 kΩ apparently works well enough. A reasonable compromise might be 1 kΩ 5 W resistors. Those should dissipate 3/4 of the power the original ones did.
Make sure to replace all four resistors with new ones of the same type, regardless of what you choose. These are basically voltage dividers, so their ratios are important.
  • \$\begingroup\$ Thank you, Olin. I'll look for alternative resistors and post the candidates here. \$\endgroup\$
    – zeron
    Feb 10, 2017 at 0:27
  • \$\begingroup\$ I added a list of resistors to the opening post of this thread. Which would you recommend as the best bet? \$\endgroup\$
    – zeron
    Feb 10, 2017 at 8:26
IF you choose 1500 Ohms the hFE in Q15,Q24 must be matched to each other very tight and the lower the hFE the tighter the requirement. Otherwise excess base loading occurs i.e. not +/-40V and this reflects to a large DC output.
If the Q15 hFE is only 30 and emitter load is est. 33 ohms then Zin is ~1K in parallel with those resistors. So hFE is a dominant factor and low hFE is a big problem. Too high hFE then adds non-linearity which is also a problem for distortion. So Q selection is just as critical as R.
For example if Q15-b gets pulled down from 40V to 20V then R87 has 60V drop and Pd=V²/R = 3600/750 = 5W
So the choice of R value has everything to do with hFe of Q15 and Q24, which is an unknown. The factory may have these matched with higher values than nominal by custom order or pre-testing. If only 1 side is exposed to air then you have to derate Pd by at least 50%.
So try 1k 7.5W and verify all DC voltages for balance and replace Q15,Q24 as required and check the other transistor DC voltages for balance as well which may indicate unbalanced hFE.
