I have built the following:
In the schematic, the LEDs represent a 12V LED strip with red, green, blue and white channels. I'm using four IRL630 N-Channel MOSFETs (datasheet).
The 12V battery is actually a 20A power supply. The 5V battery comes from a raspberry Pi's GND and +5V pins. As you can see, the negatives (grounds) of both power supplies are connected.
The Atmega328 currently has a very simple program on it that fades colors (from red to green to blue to white, indefinitely), by PWM.
Problems:
With a load of 1.2A (i.e. a LED strip that requires max 1.2A at 12V), everything works smoothly most of the time. Sometimes the Atmega will freeze and the colors stop fading.
With a load of 3.6A, the color transitions are "skippy", i.e. the fading stops intermittently and then jumps straight to the color where it should be and continues fading.
With a load of 6A, the fading works for about 3 seconds and then all MOSFETs seem to enter saturation simultaneously, giving way to a bright white full-on LED strip.
What I've tried:
I tried decoupling, i.e. a 10nF capacitor between the Atmega's Vcc and GND. The effect I observed is a super-accelerated crazy color rainbow with intermitent strobe light effects. I've removed the capacitor.
I tried decoupling as above while separating 12V and 5V GNDs (don't ask me why). It didn't work, the LEDs just kind of lit up a little bit and stayed at one color. I unplugged it shortly after.
I'm a programmer. What am I doing wrong?
Additional details
- I'm using 0.75mm² solid copper wires (18AWG according to Google), for everything up to the LED strip.
- The connectors to/from the power sources are made out of aluminium, same gauge.
