I'm experimenting with MCP73871T-2CCI/ML charger for my Arduino project. I wanted to build one by myself based on datasheet.
I have build circuit on prototyping board, according to this schematic:
Unfortunately charging current for battery is very low. At maximum, my 1400mAh LiPo is charged with current 100 mA, MCP73871 does not switch do 1A charging at all. Even, when I discharged battery completely, it does not switch to high current charging.
I need to add, that I was soldering raw chip to the adapter board by myself, so it might be that I have either broke it or it is not soldered properly.
Could you be so kind to give me any ideas how I can diagnose the reason ?
