I am trying to understand how to solve a homework problem I have. It states: Analytically show that closed-loop system is stable for all values of K.
By looking at the block diagram, I know that this is of course negative feedback with proportional control as the controller. Below, you can see my plant's transfer function and what I came up with for a closed loop transfer function.
\begin{array}{l} G(s) = \frac{1}{{{s^2} + 4s}}\\ H{(s)_{closedLoop}} = \frac{K}{{{s^2} + 4s + K}} = \frac{{N(s)}}{{D(s)}} \end{array}
I know that the poles here indicate whether the system is stable or not. Now I am not sure how I am supposed to show that every value of K satisfies stability because if I choose a vale such as K=-12, this will land a pole in the right half plane of the s-plane.
Did I mess up on getting the closed loop transfer function? Am I not understanding the question? Any hints on this one is appreciated!
