I have this PCB board that I need to solder a capacitor to it. This is the board: Solder point on PCB board, half striped half clear circle
And I'm not sure where should I solder the negative and where the positive. Can someone please explain what this circle represents on the board?
  • \$\begingroup\$ I vote for negative to the left (one with lines) \$\endgroup\$ – Gregory Kornblum Feb 12 '17 at 14:37
    \$\begingroup\$ Have you missed the plus sign (+) on the right side (overlayed with the line)? And without it, the filled area usually means minus/negative (-). \$\endgroup\$ – try-catch-finally Feb 12 '17 at 14:41
  • \$\begingroup\$ Thanks, I think I got it out by tracing he connections, it looks like the negative is indeed the one with the lines. \$\endgroup\$ – NoamC Feb 12 '17 at 14:52
  • \$\begingroup\$ Another option is to look for another capacitor in the board that is still mounted, if it exists. \$\endgroup\$ – ricardomenzer Feb 13 '17 at 11:53
Usual Silkscreen identify the shaded side is -ve (GND), also there will be + indication on the other side, looking into your picture it seems the + is merged with the white line
  • \$\begingroup\$ Bipolar capacitors are quite cheap these days. Use one. \$\endgroup\$ – skvery Feb 12 '17 at 19:05
